Engine number
Can anyone tell me what car this engine is from
engine number 6303506 |
That number doesn't show up in the charts I have. What is the Type #?
630 0001 thru 630 2480 shows as a 1970 911S, Type 911/02, mechanically fuel-injected 2.2 liter motor, but that's as close as I can find. TT |
Its a 78sc which is for sale with a 3.2 L engine in it !
Im trying to work out what car the engine came from ! |
63Dxxxx would be an 83 Euro(rest of world) engine.
6303506 looks like a euro '80 3.0L to me. My euro '80 is 6301010.
Get the engine type number. 930/09 or 930/20, etc. Rob 1980sc |
is it possible to replace the 3.0 cis with a 3.2 DME ?
heres a pic ! Is there any chance this could still be a 3.0 L converted http://forums.pelicanparts.com/uploa...1064357330.jpg |
Interesting. Looks like a 3.0 distributor with MSD ignition. I don't think 3.2 distributors had vac advance units, or were adjustable for timing (the slot on the mounting stud).
It may be possible to use the DME from the 3.2 with a old style distributor and just ignore the ignition signal, but I haven't heard of anyone doing it. It is also a step backwards from the DME controled timing curve of the 3.2. You would have to change the drive gear on the crank because a 911 SC 3.0 distributor turns the opposite direction of every other 911 engine. It could also be an aftermarket EFI setup using the 3.2 manafold. I think Clewett does this, but their systems also have crank-fired ignitions with coil packs (at least when I looked into it). Curious. Get the engine type number. Tom Edit: Spellin' |
mystery engine...
the 911 redbook pg. 71 indicates that it could be from a 911SC Aug 79 through July 80 #6300001-on (930/09) 4,831 produced.
Shawn. |
oohh ..
This is getting more interseting. This is quite a wierd engine ! Clearly this is not a genuine 3.2 carrera engine is it ? |
bump
Did you find the engine type number? That is the best way to narrow down what you have.
| All times are GMT -8. The time now is 07:01 PM. |
