Problems with ignition switch removal
Hi guys,
I've just attempted to remove the ignition switch assembly from my 83 SC. I've followed the instructions in 101, removed the 2 break-off bolts, removed the bolt that holds the other end to the steering column. It wobbles about but I can't pull the switch far enough to the right (RHD) to free the end from the steering column. Am I missing something here?? Cheers, Tim. |
Forget it guys,
Just found an old post of John Walker's - looks like the rivets have to be drilled out of the mounting plate as well. I was going to delete this thread but for some reason it's not letting me!? Cheers, Tim. |
| All times are GMT -8. The time now is 08:57 AM. |
