GrindingGears's Avatar
How do you warm up your 911...
How do you warm up you 911 in the morning?
I let the car run for a couple minutes, sometime I hold a rev at 1500k, then go...shifting at 3k until oil temp is warm. Just wanted to hear what y'all do...
83 SC (gone) // 72 T (gone)
Old 09-24-2003, 01:03 PM
Gon fix it with me hammer
svandamme's Avatar
driving, gently not to much revvs
slowly building up the driving style
but i'm a newby so i'm open for suggestions too.
Stijn Vandamme
BIMDIESELBMW116D2019
Old 09-24-2003, 01:09 PM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
I keep my rev's under 3K til the oil temp reaches about 170 before I slowly rev higher til I get to redline.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 09-24-2003, 01:16 PM
svandamme's Avatar
oil temp up to 170?
mine kinda levels out at 90 - 100
but haven't really pushed it cause i don't know what's normal and what ain't
Stijn Vandamme
Old 09-24-2003, 01:18 PM
Tim Walsh's Avatar
170 F that translates to about 80C I belive.
Edit: that comes out to be 77c or so.
Tim
1973 911T
2005 VW GTI
Old 09-24-2003, 01:21 PM
svandamme's Avatar
mine's an american , so no Celcius either
at least the speedo is in miles...
the temp gauge has 50 as min mark , then 80 , then 100 in the middle
the upper ones i can't say off the top of my mind, i think it's 120 and 150
Stijn Vandamme
Old 09-24-2003, 01:22 PM
Hilbilly Deluxe
emcon5's Avatar
ºC vs ºF
Tom
82 911SC Coupe
GTI Cup #43
It's probably been converted to Celsius.
Neil
'73 911S targa
Old 09-24-2003, 01:23 PM
Tim Walsh's Avatar
umm 100 f would be a hot day over here. I'm almost sure you're getting higher than that.
Tim
1973 911T
2005 VW GTI
Old 09-24-2003, 01:24 PM
svandamme's Avatar
don't matter that much , the needle doesn't go over the middle, and i'll keep it that way , no performance driving till i'm confident that everything is ok
Stijn Vandamme
Old 09-24-2003, 01:25 PM
mackpipes
Guest
Posts: n/a
I leave a brick on the accelerator until it starts smoking. It has to be warm to smoke, right?
91C2wrencher's Avatar
First it's bad to "warm-up" a dry sump engine by letting it idle. You should do something like the following, Start car, drive car under 4000 rpm until there's heat in the gauge(needle moving up) then anything but redline until it's fully hot. Then she's ready to rip! Incidently, cool down is of the same importance, never put her away hot, do some e-a-s-y miles before the garage.
1991 964 C2 -SOLD - miss it everyday -
2009 Honda CRV
2007 Audi A4 Quattro - just a sweet personal car -
2000 Land Rover Disco II - lifted
2001 GMC Seirra 1500HD CREWCAB
Old 09-24-2003, 01:26 PM
svandamme's Avatar
mine smokes right from the start when it's been in the garage for more than a fortnight
Stijn Vandamme
ZAMIRZ's Avatar
turn it on, wait 30 seconds, back out of the driveway and keep it under 12 o'clock on the tach until the temp needle is midway between the fat white mark and the 1st skinny white mark.
Amir
'83 911SC
Old 09-24-2003, 01:28 PM
I'm off the hook.....
I keep the revs below 5 bar on the oil pressure guage until the oil temp is off of the cold peg. Usually happens about the same time. I have about 20 blocks of city driving before I hit the onramp to the (so-called) freeway.
No, I don't sing. Based there for too long.
Old 09-24-2003, 01:31 PM
My engine doesn't seem to have a temperature sensor, so I try to keep it between 3k and 5k (engine doesn't run much under 3k, and its lugging anyway) until my oil level gauge goes from 5l to 7l. (Not sure why it sees a 2l change in the first five to ten minutes of driving, but when it says 7l, the car is good and warm, so its the best I can go by until I work out why the engine doesn't have a sensor, and where the heck the wire is that ought to plug into one if I added it)
1968 911L
2004 Dodge Dakota SLT Plus
Old 09-24-2003, 01:45 PM
goat's Avatar
I follow exactly 91C2 wrencher way.
My Mechanic told me about the same thing too.
Warm-up and the cool-down, which just as important.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 09-24-2003, 01:50 PM
When I bought my car from the original owner he told me his warmup procedure which was to set the hand throttle at 3000RPM and let run for 3-4 minutes. I thought he was absolutely nuts, but have since learned this is not bad advice for a dry sump engine. And it's tough to argue with results. Many, many miles on engine and it runs like new.
Old 09-24-2003, 02:34 PM
Mr9146's Avatar
What is this "warm up" crap? Just turn the key and go. The more you drive, the warmer it gets, right?
Old 09-24-2003, 02:46 PM
svandamme's Avatar
true, but it ain't going to help your engine in the long run to run high revvs on cold metall/oil.
maybe not that big a deal in CA , but it does matter in places where the sun don't shine that much.
Stijn Vandamme
Old 09-24-2003, 02:58 PM
