Red face car not starting after sitting for an hour
I have a 1979 911SC European Model. I noticed recently after driving the car for some time, when I shut it off and let it sit for 45-60 minutes when I try to start it again, it will not start.
I can hear the electric fuel pump running, but the car just cranks and cranks but no sign of it kicking over (lack of spark or fuel?).
If I wait several minutes and keep trying it will eventually start.
When it is running the car seems to run normal.
Any ideas. It just started happening last month.
Thanks,
TBAHR
Old 09-26-2003, 10:29 PM
Oracle's Avatar
Hi,
I've read that this can be caused by:
a) Bad seal in the fuel Pump
b) Bad fuel Accumulator
c) Fuel Inyectors leaking
There are many threads about this same topic.
Bye
-J
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 09-26-2003, 10:48 PM
davis911s's Avatar
My guess is your check valve on your fuel pump. I had to replace mine 2 years ago.
Can the check valve be replaced independently of the fuel pump?
Your symptoms are exactly what mine were. The check valve was the culprit for me, a pretty easy fix too.
Good luck
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 09-26-2003, 10:51 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
What would be the difference in symptoms from a bad check valve as compared to a bad accumulator?
Yes I have searched but there seems to be conflicting information.
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 10-01-2003, 11:40 AM
From what I've seen in other CIS cars a bad accumulator will allow a "warm" start after prolonged cranking.
Warren & Ron, may you rest in Peace.
Old 10-01-2003, 12:01 PM
IROC's Avatar
Well, basically there is no difference. Both problems allow the system pressure to bleed down once the engine is shut off. Now, you could (depending on where in the system you connected a pressure gauge) determine which one of these was the culprit.
The funny thing is that I have never understood how a check valve "goes bad". Does some crap get stuck under the seat and not allow it to close?
In my case it was a bad fuel accumulator. Check valve was fine.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-01-2003, 12:02 PM
Mark Wilson
Guest
Posts: n/a
My 79 did the same thing. It was the check valve. Many people with much more knowledge than I told the accumulater rarely goes bad.
Old 10-01-2003, 12:27 PM
