-   -   3.6 coversion (http://forums.pelicanparts.com/porsche-911-technical-forum/129637-3-6-coversion.html)
mjshira 10-02-2003 09:08 AM
... only much better put by you.
ChrisBennet 10-02-2003 09:13 AM
Originally posted by Bill Verburg
Mike, be sure to remove and plug the SAI system. The B&B headers wil work well on a 993 w/Thoms heat tube
http://forums.pelicanparts.com/uploa..._008_small.jpg
Since you're likely using a 55 pin Cyntex chip the SAI is totally redundant dead weight.
Forgive me if this a stupid question but what's "the SAI system"?
-Chris
Bill Verburg 10-02-2003 11:45 AM
SAI is a little electric pump and associated hardware that blows into the heads thence to the exhaust ports. It is a feature of US OBD2 993s that causes no end of trouble for the owner. The intended function is to blow extra O<sub>2</sub> into the exhaust port for a few minutes after a cold start. In practice it gets plugged up w/ gunk, the net effect is a thrown code, causeing a CEL(check engine light)
The euro versions do not have this "feature"
ChrisBennet 10-02-2003 11:55 AM
Thanks Bill!
SAI = Something Air Injection :D
-Chris
Bill Verburg 10-02-2003 12:54 PM
Secondary Air Injection
here's a pic I stole from Rennliist
http://boards.rennlist.com/upload/carbon.jpg
Showing a plugged up port. Here's the thread
mjshira 10-02-2003 01:20 PM
Bill, any chance you'd post some audio of your engine? It must sound awesome.
Bill Verburg 10-02-2003 01:25 PM
Here's a short one in the garage Sound
I've got a lot more long ones but need to figure out how to edit mpgs to a reasonable size.
Kahuna 10-02-2003 02:05 PM
It sounds even better in person, Bill took me for a ride the other night when I was looking at some calipers, Wheeeee!:D
obrut 10-02-2003 02:35 PM
Boost
I don't know how north you are but there is a heap of early and mid 911s in Sydney with 3.6's in them. My mech has done a fair few including one finished in the last fortnight and doesn't seem to consider it much of a biggie. Might be worth the trip - pm me if you need contact details.
Cheers - Ryan
LeeH 10-02-2003 03:01 PM
That was spine tingling good! Who knows what would have happened if it had been one of the long versions! http://www.pelicanparts.com/support/smileys/nuts.gif
mjshira 10-03-2003 05:15 AM
wow! v-cool Bill. I think I am going to have to invite myself over one afternoon for a personal inspection of that beast!
