Roof spoiler and 3rd light hookups
I just ordered a roof spoiler from Ebay (I think I outbid Zeke..) which includes a third brakelight.
How hard is it to do the wiring for the brake light with this spoiler and a '86 911? Anyone done it? [IMG]http://assets.************************/assets/product/105501/105501_200_1.jpg[/IMG]
2014 Porsche Cayman S 2001 BMW 525i Touring 1996 Porsche 911 (Gone to Germany) '86 911 Carrera (Gone to Aruba) |
1.367m later
Not hard at all. I have one of those on a customers car. I installed it as part of a total repaint so the back window was already out. I fed the wires through the window seal as I installed the window. It might be a bit harder if you don't plan on removing the rear window to install it.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Hmm :/
here is an exploded view. there are small "blocks" with bolts in them that adhere to the glass. the spoiler pieces are fastened with the bolts.
running the wire may be the tricky part. i will see if i can find some instructions regarding install. max
max |
moazam, there are about six pages of instructions/diagrams in the factory manual. If your roof spoiler comes with no instructions, let me know and i will email the instructions to you.
max
max |
Moazam--
do a search - there are several very detailed threads on this. the short answer is that in there is a hole below the lower left hand corner (driver's side) of the rear window where the wires for the rear window defroster/defogger pass into the engine compartment. From the engine compartment its near the left hinge - you'll have to remove the rear shelf to gain access to it from the passenger compartment. Tying into the braking circuit is easy - there are only 2 wires. You just tap into the left rear brakelight circuit and ground the other (there is a ground behind the fuel filter on my '85 Targa). As I said, do a search - I think RickM posted pix of the wire tap from radio shack that you'll need, etc. try these threads: rear brake light thread CHECK OUT THE EMBEDDED THREADS in the thread for more details
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member Last edited by steve911; 09-30-2003 at 11:47 AM.. |
Here are two good threads regarding the electrical aspect of your project...
Wiring 3rd Brake Light Wiring 3rd Brake Light
Warren & Ron, may you rest in Peace. |
Driving member
If you have an 86 like mine the brake light is already in the back window on the inside. The 2 wires that go to that light just need to be fed out to the new light. No real mystery as far as wiring.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
How much downforce does this spoiler provide and doesn't it block the vents in the roof above the rear window?
Harlan Chinn Pacific Northwest Region 1998 Carrera S ArcticSilverMetallic 1982 911SC PazificBlauMetallic |
