SLR SLR is offline
SLR
Clutch cable ajustment
Hi all!
I’m interested in comments about my 915 clutch / cable. today I went t o adjust the cable and found that the small arm would not return all the way back, it would return so far and stop but if I pushed on it it would go all the way back. So when I Ajusted every thing to the right spec’s then jump on the clutch it felt smooth but had to much play at the top of the travel, so now I have compromised and ajusted the cable so as there next to no gap at the adjuster bolt. Do you think I need new “C” spring or how about a rebuilt of the mechanisim?. The cable its self is smooth and not catching any where.
Cheers Steve
Old 09-27-2003, 05:58 AM
I think there is supposed to be some play at the top. Where does the clutch engage?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 09-27-2003, 01:23 PM
SLR SLR is offline
SLR
The clutch engages at about 1/3 the way up the travel.
Old 09-28-2003, 01:37 AM
Cool
yeah Dean..
when the pedal is free from the foot you should then be able to hand pull the pedal up a little higher.. I think the info is in Wayne's book..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 09-28-2003, 09:47 AM
I was having all kinds of problems with mine not feeling right and getting stuck in the down position. I adjusted it a million times. I tried it without the C spring and it was to hard and then without the sping under the floor board, wow just right, works better than ever and has just the right feel. I hear it is hell to get the spring back on, be aware.
I like them I drive them
Old 09-30-2003, 06:29 PM
JC930's Avatar
With cable disconnected adjust screw to 1.2mm, tighten up adj. screw with lock nut. Now attach cable and tighten up cable so your clearance decreases to 1.0mm. You should end up with 25mm +-.5mm of travel.
jc930
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 09-30-2003, 11:10 PM
Senior Member
Jdub's Avatar
Don't forget to limit the overall travel at the floorboard using the stop provided for this purpose. This is a two man job: one person under the car measures overall "throw" and the other person pushes the clutch pedal in.
The information is in the Bentley/here at the site.
John
'78 Targa in Minerva Blue
Old 10-01-2003, 07:08 AM
