RickKlem's Avatar
Location: Seale, Alabama (25 miles south of Auburn, Al.)
How do I measure my brakes for pads?
I need to order front brake pads for my 77 . I know that they are steal but I need to choice between two sizes. What do I measure to determine which pad I need. I have heard that you measure the diameter of the pistion and I also heard that you measure the width of the old pad. Can someone please post a drawing and point to the two points to measure.
Rick
Red 1977 911s 3.0L (27230)
2013 Base Cayenne 3.6L
Old 10-09-2003, 07:34 PM
makaio's Avatar
Out of curiousity, why do you need to measure them? Is it because you have none OE calipers?
Old 10-09-2003, 07:41 PM
JC930's Avatar
Pull off the pads on one side of the car and take them with you when you pick up the new ones.
jc930
77' 930 turbo carrera silver SOLD
03' SL500 Mercedes Benz white
06' GMC Yukon Danali white
15' LTZ Chevy Suburban black
07' 997 tt black
Old 10-09-2003, 11:12 PM
AES AES is offline
Bill Verburg posted the outlines a while back, search on his name.
Old 10-10-2003, 03:49 AM
RickKlem's Avatar
Matt
No the oem's are still on the car, but when I went to order them on Pelican parts , it shows two different sizes for my year car, and I'm not sure what they are measuring.
JC930
The problem with that is I order all of my stuff From our Host, Pelican Parts.
AES
Thanks, I will search on it.
Rick
Old 10-10-2003, 04:57 AM
Bill Verburg's Avatar
They are either A which has a 3.5" mountiing bolt patten or M which has a 3" mounting bolt pattern
Your calipers are likely not this clean but A is on the left M on the right
Bill Verburg
Old 10-10-2003, 12:53 PM
OEM Front Brake Pad Set, Aluminum Alloy 'S' Caliper, 911 (1974-77), 911 Turbo (1976-77)
C-351-950-03 $45.50
OEM Front Brake Pad Set, Steel 'A' Caliper, 911 (late 1975-89), From VIN# 911-520-2046 (Coupe), 911-521-1218 (Targa), 911-540-0342 (Carrera Coupe), 911-541-0148 (Carrera Targa)
C-351-950-02 $31.25
the Alloy "S" caliper pads are slightly thicker
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-10-2003, 03:44 PM
