Ho Hum 74's Avatar
Where to get oil cooler cleaned?
Hi,
Rebuilding my 2.7 RS engine after the #3 big end bearing packed it in for the day.
Where can I get my oil coolers cleaned? Are there any locally in Chicago?
Also, are there any local Chicago machinists that can fab parts?
Tristan
Old 10-06-2003, 03:44 PM
makaio's Avatar
Personally I would junk them and buy new. JMHO. Because if they were not cleaned good enough, all that hard work and $ would be down the drain.
I'm now putting on my nomex suit for the flames
Old 10-06-2003, 04:06 PM
Irrationally exuberant
ChrisBennet's Avatar
I sent mine to Pacific Oil Cooler.
Just a happy customer.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-06-2003, 04:10 PM
RETIRED
Joe Bob's Avatar
Buy new.....piece of mind is worth the 400 bucks.....
http://www.batinc.net/mocal.htm
2012 ML350 3.0 Turbo Diesel
Old 10-06-2003, 04:34 PM
Don't forget the engine oil cooler (PP price: $900+). Assuming you don't mind using a $400 Mocal in place of the factory external cooler, is piece of mind worth $1300? If it's good enough for airplanes (FAA certified) it's good enough for me.
-Chris
Old 10-06-2003, 05:49 PM
RETIRED
Joe Bob's Avatar
-Chris
I use my Mocal in line with the stock one I got from Parts Heaven....they are preceeded with a thermostat and I also use a pre oiler (Accusump).
Old 10-06-2003, 06:03 PM
Ho Hum 74's Avatar
Thanks everyone. I just installed my 70 row Mocal unit upfront in the spoiler and was very happy with the results. Chris, how much was the cleaning?
Tristan
Old 10-07-2003, 04:36 AM
Licensed User
Shuie's Avatar
Chris, do you know if they will clean an oil tank as well as the coolers?
Old 10-07-2003, 04:59 AM
Which car are you talking about Mike (356/914/911)?
(I thought you were talking about the 911 until you mentioned the Accusump thing.)
-Chris
Old 10-07-2003, 05:49 AM
I think cleaning was around $80 each a few years ago. You need to clean everything, hoses, thermostats, remove oil gallery plugs in motor, everything. Despite a sump full of bearing chips, I didn't find any bits in the oil tank or lines.
-Chris
Old 10-07-2003, 05:52 AM
RETIRED
Joe Bob's Avatar
-Chris
I stuck one in the 911 too....liked the idea of oil pressure on start up.....especially when i added up how much I had in the engine.
Old 10-07-2003, 06:22 AM
