-   -   Wierd Hot Start Problem (http://forums.pelicanparts.com/porsche-911-technical-forum/130490-wierd-hot-start-problem.html)
Par911 10-06-2003 07:42 PM
Hey Pelicans, My 911SC is acting up on me, I drove the 911 the whole day, running errands. I take her out to the grocery store in the evening, and when I get to my house, I shut the ignition off. A minute later, I realized that I need to move my car(don't want to risk any door dings from my neighbors vehicle). So I go to start her up again and she won't start. The motor makes the noise like she wants to turn over, I hear the motor crank but not fire up. It is strange because this problem only happend a few times, and only after being driven hard. I have never had this happen after my 911 had been sitting. From a cold start, my SC fires up real strong, the motor idles at 1300-1200rpm then levels out at 950-1000 rpm. So I left the 911 alone for 3 hours and went outside later, turned the ignition and it started strong as ever. :confused:Has anyone had similar start problems that come and go? I have heard about hot start problems being related to problems with the fuel pump and fuel alternator, but both of these parts are fairly new in my car. On a more positive note, I completed my first 911 projects yesterday, changing the brake pads and rotors, wheel bearings, and performing an oil change. I had a friend who is knowledgeable with p-cars help me with these tasks, thanks Dane.
Par911 10-06-2003 08:19 PM
Here are some details as to what my car has:
The motor was rebuilt 6,000 miles ago by P.O.'s friend:
- all heads rebuilt with all new parts
- cams reground by webcam
- all new bearings and seals
- polished the crank
- new time chains and guides
- entire rebuild kit from Vertex
- low mile p/c set from an 82 SC (the old ones were good, but the PO stumbled onto these with 60K on them. a 82 is also higher compression ratio)
- new ignition wires (steel braided)
- new turbo valve covers
- new fuel pump
- new fuel accumulator
- new turbo tie rods
- pop off valve
- carrera chain tensioners
- new rebuild on the alternator
- nice bilstiens (4)
- new sachs clutch pack
- re-ground flywheel
- all new seals and gaskets in the 915 ( PO inspected the 915, all good)
- all new CV joints & boots
I had a mechanic adjust the CO to the proper level and set the idle level to correct specs last week. I replaced the spark plugs 3 weeks ago.
Par911 10-09-2003 05:32 AM
Fuggetaboutit.....I figured the problem out today, apparently some PO had hacked into the fuel pump wire running from underneath the fuel relay. Whoever did this, chose the cheap route and used a buttonclamp to reconnect the wires instead of replacing them. So the connection was getting loose, causing my 911 to have start problems. I took the car to C&J motors and they are soldering a new wire in. Looks like problem solved.
azasadny 10-09-2003 06:04 PM
Pari,
Great news! I'm glad you found the problem so quickly. My "starting issues" took several frustrating months to finally resolve. Happy driving!
