Send a message via Yahoo to 911Brian
Creaking noise from rear.
When I just start to take off in my 80SC, I hear a slight creaking coming from the rear. I read up on CV joint noise on this board and I don't believe that is it. It only happens when taking off. After rolling, the car is quiet, even around corners, on decel, on accel.....
Any ideas?
86 Carrera Red/Black
80 SC Coupe Silver/Black (gone but not forgotten)
Old 10-08-2003, 10:37 AM
Senior Member
Jdub's Avatar
So only the first acceleration, none after?
John
'78 Targa in Minerva Blue
Old 10-08-2003, 10:55 AM
John
Just about every start. It does it in reverse as well.
Old 10-08-2003, 11:30 AM
Senior Member
Jdub's Avatar
Transmission mounts possibly? Sway bar moving (spray silicone spray at bushing-to-sway bar and retest)?
John
Old 10-08-2003, 12:26 PM
John
I will give those a shot hopefully this weekend.
Thanks!
Old 10-08-2003, 12:34 PM
Sounds like the description when my 88 broke a sway bar mount.
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 10-08-2003, 12:36 PM
I hope that is not the problem... I have an autox in 2 weeks
Old 10-08-2003, 12:38 PM
Double Trouble
targa911S's Avatar
I had a similar problem. Found a dried out shock absorber in the rear. So much for the lifetime guarantee on Konis!
I used to be addicted to the hokey pokey..........but I turned myself around..
75 914 1.8
2010 Cayenne base
Old 10-08-2003, 04:33 PM
I thought it could be that but when I push down on the car I can't hear anything.
Old 10-08-2003, 05:13 PM
All excellent suggestions! I am all over it this weekend
Old 10-08-2003, 06:28 PM
Well, I crawled under the car and couldn't see anything noticeable. My CV joints are rock solid and all mounts look good under there. I guess it is some bushings somewhere making noise. I am not going to sweat about it anymore unless it gets worse.
Thanks for all the help!
Old 10-12-2003, 05:40 AM
