-   -   manual window crank binds halfway down (http://forums.pelicanparts.com/porsche-911-technical-forum/131014-manual-window-crank-binds-halfway-down.html)
billwagnon 10-10-2003 09:30 AM
I took my doors apart last March and cleaned and lubed everything. The windows went up and down fairly easily. But lately the window is tough to crank about halfway down (or up).
Is this a problem with the infamous pivot pin? Once I select the matching one is that all I will need?
billwagnon 10-10-2003 09:35 AM
also, does Pelican carry these? I found all the window stuff via search but it looks like you have to get the whole regulator.
dhoward 10-10-2003 10:03 AM
Bill, I had the same problem on my passenger side. The window channel felt thing got bunched up near the bottom. Replaced it and it smooth as 34 year old silk.....
You might check for that....
billwagnon 10-10-2003 08:41 PM
thanks! I'll check that out.
gerard vaglio 10-10-2003 09:30 PM
window felt
I also had the same problem Bill, purchased the window felt, problem gone! If it's the same problem you'll be very happy with the results.
good luck.
