billwagnon's Avatar
manual window crank binds halfway down
I took my doors apart last March and cleaned and lubed everything. The windows went up and down fairly easily. But lately the window is tough to crank about halfway down (or up).
Is this a problem with the infamous pivot pin? Once I select the matching one is that all I will need?
Old 10-10-2003, 09:30 AM
billwagnon's Avatar
also, does Pelican carry these? I found all the window stuff via search but it looks like you have to get the whole regulator.
Old 10-10-2003, 09:35 AM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Bill, I had the same problem on my passenger side. The window channel felt thing got bunched up near the bottom. Replaced it and it smooth as 34 year old silk.....
You might check for that....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 10-10-2003, 10:03 AM
billwagnon's Avatar
thanks! I'll check that out.
Old 10-10-2003, 08:41 PM
gerard vaglio's Avatar
window felt
I also had the same problem Bill, purchased the window felt, problem gone! If it's the same problem you'll be very happy with the results.
good luck.
Old 10-10-2003, 09:30 PM
