-   -   failed smog, question time (long) (http://forums.pelicanparts.com/porsche-911-technical-forum/131425-failed-smog-question-time-long.html)
sammyg2 10-13-2003 01:44 PM
My basilcally stock 1980 SC failed smog today three times. I had to take it to a test only station.
I leaned the mixture just a little tiny bit before I went the first time, I drove it around long enough to get it up to full temperature.
failed on excessive CO, reading was 2.75%, almost twice what is allowed. HC was a little higher than average but well below max.
I took it to Steve's independant Porsche shop, he put it on the smog tester and leaned it out some more until the CO read .18%
Back to the test only station, failed again on CO, this time at 2.4%
This car passed easily two years ago and at the time I had the O2 sensor disconnected.
So, I went home, disconnected the O2 sensor and leaned it out some more until it started to idle slightly rough.
back to the smog station, same results, almost identical readings.
I went back home and let it cool down for a while and then changed the O2 sensor with a known good spare I had. The car started right up but the idle settled down at around 550 and rough.
It had cooled down but was not stone cold.
I drove it for 5 miles, after a minute or so the idle came back up to around 850 and it ran smooth.
My wild a$$ guess is that the O2 sensor was partially bad, and that I might have a slight vacuum leak at idle. that would explain why it runs clean at idle but not at 2500 rpm on the rollers. The O2 sensor would explain why the idle came back up, maybe it was running real lean at idle and after the O2 sensor warmed up it made the necessary adjustments. Does that make any sense or am I way off base?
I plan to change the oil and air filter before re-testing again even though they have very low miles on them, probably plugs at the same time.
Any other suggestions before I have it tested for the 4th time? Anyone?
This is getting expensive and I can't wait to get everything re-adjusted to where I like it.
This is where I would normally say that living in Kalifornia sucks, but it's 85 degrees outside right now. Maybe it only sux a little ;)
nostatic 10-13-2003 01:47 PM
Re: failed smog, question time (long)
My son and I were at the beach from 1pm until sunset yesterday. In swimsuit and t-shirt.
It sucked *very* little at that point in time.
juanbenae 10-13-2003 01:48 PM
are you being required to do the "test 2" type? that being the dyno type. i hurried and got all my rigs done prior to oct 1 when it changed here in the bay area. it is suppose to fail about 30% of the cars that would have passed the old test.
sammyg2 10-13-2003 01:50 PM
They put it on the rollers and tested it at 15 and 25 mph, is that the test 2 type?
Oh, the good news is that my gas cap passed the gas cap test ;)
Bob's Flat-Six 10-13-2003 02:50 PM
My 80 SC was tested back in 6/03 and passed on the rollers, in fact everytime I've had it tested (3 times) it's been on rollers and passed everytime.
The CO measured .42 at 15 mph and .15 at 25mph. It's pretty much stock and the readings on all the test have been in the same range.
I'm not sure what is causing your's to fail, Sammy
But I'm curious if a Cat going bad could be the problem?? but thats just a guess :)
HarryD 10-13-2003 03:20 PM
Let's talk a bit of chemistry here. T
his is the chart from Bosch Fuel Injection & Engine Management (thanks Steve W). The solid line is with a cat and the dotted line is without one.
http://forums.pelicanparts.com/uploads/EMISSION.gif
Anyway, you can see from this chart that by making the mixture more lean (less excess air), you drive the CO down, but the NOx and HCs go up.
A question is how do your HC's and NOs look. If they are high, it is possible your catalyst is dead. If so, you may notice that the CO is the one most greatly controlled by the catalyst and this could be why you are not passing.
Hope this helps a bit.
tobluforu 10-13-2003 03:23 PM
Bad cat and o2 sensors will cause all sorts of havic when testing. Run low octane gas; tune car up, retard timing a few degrees. If cat is old-replace. Same goes w\o2
Doug Zielke 10-13-2003 06:16 PM
Sam,
I just smogged the 'Bomber a couple of weeks ago. Our test stations here are modeled closely on CA specs, so they are pretty tough.
First off, I do *not* run a cat. My car manages to get through on a 'loophole' in the rules without one. All I did was lean the mixture to around 0.5% CO (using my Gunson), connect the O2 sensor, set the timing to around 0 BTDC, and roll to the test. Oh yeah....I filled the tank at a station that dispenses gas cut with 10% Ethanol.
The car passed with ample margin on *all* the exhaust gases. Still, no cat.
What puzzles me about your test, is how you wrench could set it at 0.18%, and yet it fails the test with a much higher reading.
What is happening there??
If your motor has a functioning cat and 02, you should pass with ease.
makaio 10-13-2003 06:46 PM
Not to higjack your thread Sammy, but is it possible for a California resident say in Orange County, to have a smog test done in Shasta County? Or does it have to be the County in which you reside in?
sammyg2 10-13-2003 06:59 PM
The owner of the Porsche shop set the CO with the car idling, but the test was done on rollers at 15 and 25 mph.
That's the part that bothers me the most, the car was lean at 900 rpm but went rich at 2500 rpm during the test.
I do believe the O2 sensor was suspect, but the only other explaination I can come up with it either a vacuum leak that has more effect at idle than at 2500 rpm, or the air flow metering isn't linear to the fuel flow.
Still sctartching my head on that one. My CIS books are at work, I bet you can guess how much actual work I'm going to get done tomorrow morning ;)
I really need access to a gas tester so I can diagnose and tune it. I can't afford to keep going to a shop to have fine tuning done when it doesn't accomplish getting the car to pass.
I also can't rely on tuning it by ear (obviously). I've gotten by for too many years doing it that way but this time I need to be more precise.
Matt, sorry I can't answer you question, I have no idea. Have you checked the Ca. DMV website for a FAQ or something?
makaio 10-13-2003 07:05 PM
Yes, I have looked at it, but it was a couple years ago. I was just thinking that if you guys in the "rolling test" counties could test outside the county your car was registered in, say like the county I live in that doesn't do rolling test, it would be easier.
Joe Bob 10-13-2003 07:34 PM
Chock the front wheels and put the car on jack stands.....rev her up in gear.....:eek:
scottb 10-13-2003 07:48 PM
Try taking it to a different test station next time.
Early_S_Man 10-13-2003 08:38 PM
Sam,
O2 sensors don't fail 'partially!' It is probably the cat ... how many miles on it ?
At this point, it sounds like you have already spent about what a Gunston would have cost you ...
Get one and do a test as MikeZ suggested at 2500 rpm in 1st gear with tail up on jack stands. It would also be a good idea to drive the car for at least 30 minutes at highway speeds just prior to going to the next test.
emcon5 10-13-2003 09:24 PM
Matt, I'm not positive, but from experience, I believe the CA DMV knows what test is required where the car lives, and if you tried to get a "enhanced area" car checked somewhere else, it would reject it.
Before I bought it, my SC was registered in Sacramento, which was aparently an "enhanced" area. When I tried to smog it for license renewal, the (networked to the DMV) smog machine spit out an alert that I had to go to a "test only" station, with no indication as to why.
At the time there were no test only stations in the Bay Area. I called the phone number the smog place gave me, and after being on hold and bounced around between 4 or 5 people, I was told that it was because it had been registered in an enhanced area. They made some change at their end which took the "test only" flag off and it passed with flying colors.
As of a couple weeks ago, the SF Bay area is enhanced, and we need to do the rollers now.
Tom
emcon5 10-13-2003 09:26 PM
On a related note, do you have the option of what gear you are in for the test? Couldn't you do it in 4th gear, which would be damn near idle? How does that work?
Tom
(who needs a smog check early next year)
Kurt B 10-13-2003 09:31 PM
I passed (failed for NOX) by putting in an O2 sensor --had the guy dig in boxes for a 3 wire one that I could wire in rather than spend $$ on the original type which is 4 times more...
Richened it up to 3% and put lots of octane booster (to keep NOX down).
In your case, you need to lean it out more and then put in octane booster, and make sure O2 sensor is working.
dvkk 10-13-2003 10:26 PM
Placing the rear on jackstands won't do anything for you. You could rev it to 2500 in neutral and do the same as driving it in the air. The test in the smog station applies a significant load on the engine, changing the way the FI system reacts compared to reving it to 2500 in neutral.
Your running the car for years with the O2 sensor disconnected will have certainly killed the CAT. I don't understand why so many on this board disconnect the O2 sensor.
When they have the car on the rollers what gear are they using for the 15 and 25? If they shift into 3rd for the 25mph test the engine will be lugging, causing the NOx to climb. Ask if they are allowed to leave it in 2nd. If they have an rpm limit, you can temporarily install taller tires to drop the r's to within their limit. Where I live, the 25mph test is dictated to be in 2nd, and on 2 occations I have caught the guy shifting into 3rd.
Kurt B 10-14-2003 06:59 AM
didn't see this;
"900 rpm but went rich at 2500 rpm during the test."
That sounds like an airflow meter problem. Two years ago, when I was a "gross polluter" I was OK at idle, then my CO went through the roof under load. Replaced the airflow meter, and it passed. Now I have other problems (misfiring cylinder or something), that's making it hard--but I did still pass.
Doug Zielke 10-14-2003 07:54 AM
There is *no* airflow meter on a CIS car.
Sam....I gather you are still running a cat?
If so, the idea of a bad (dead) O2 sensor killing the cat makes sense.
sammyg2 10-14-2003 08:01 AM
I ran for the past 18 months without an O2 sensor, but that was also with a test pipe. I put the cat back on Sunday and hooked up the O2 sensor so I didn't run the cat without the sensor. It is possible the sensor damaged the cat I guess.
If the cat was bad would that show up as increased HCs?
BTW, I found out from a poster on Rennlist (who works for the Bureau of Automotive repair) that in california if you get designated to go to a test only station and your car fails you are obligated to spend the first $100 to fix it, after that the state will pick up the tab for the next $500.
You can bet I'll be taking advantage of that program.
HarryD 10-14-2003 08:43 AM
sammyg2,
A bad cat will have all three elevated, especially if you are running lean. Check the charts I posted above to see how it changes the readings.
sammyg2 10-14-2003 10:50 AM
Thanks Harry, that's what I thought. Since the HC and NO readings were reasonably low I assumed the cat was doing it's job, it was just a situation that the mixture went rich at partial load and 2500 rpm and the O2 sensor didn't make the necessary adjustment to control the CO.
I'm going to get this resolved, and not just to pass the test. I want it to run the way it was supposed to run, even if I couldn't tell there was a problem until the smog man told me so. ;)
I've been pricing the gunson gas testers, looks like around $150 is the going price. Anyone know of a cheaper source?
Eugene at Pelican Parts 10-14-2003 11:19 AM
Read this
Hope it helps.
:p
Doug Zielke 10-14-2003 11:33 AM
That's a good post, AW.
I can see you're a guy who knows right from Wong.
sammyg2 10-14-2003 12:06 PM
Darn internet security thing at work blocked access to that link. I'll have to wait til I get home.
12own911 10-14-2003 12:11 PM
send me your email addy and I will send it right over. Would Word be ok?
emcon5 10-14-2003 12:37 PM
From the link above, credited to "William R. Watt"
The following guide is intended to help the owner of a car which has
failed an emissions test to understand what may be wrong with the car.
Since I am not a mechanic it may contain emissions :-) or errors. If so
I'd appreciate comments as it is intended for emailing to peope who post
emissions queries in the rec.autos. newsgroups.
thanks.
Emission (smog) test problems.
What to look for when any of CO, HC, NOx too high.
CO: rich fuel mixture
HC: incomplete combustion
NOx: hot combustion and rich fuel mixture
CO, HC, and NOx: incomplete exhaust conversion
80%-85% of vehicles pass emissions tests.
an in-tune well-maintained vehicle should pass.
allowances are made for the age of the vehicle.
for the rest some details are provded below.
note that both CO and HC rise in the absence of O2 (oxygen) in
combustion and in exhaust, and that NOx rises in the abscence of
O2 at high combustion temperature. HC also rises when there is
too much O2 in combustion.
1. CO (carbon monoxide) too high.
causes:
a) not enough air (oxygen) in air/fuel mixture to make carbon
dioxide (CO2) so get carbon monoxide (CO) instead (mixture too
rich). can be too little air or too much fuel in mixture.
b) not enough air (oxygen) in exhaust system to convert CO to CO2
c) faulty catalytic converter.
look for:
a) too little air - dirty air filter, stuck choke, plugged or
sticking PCV or EGR system, plugged carbuettor or injector air
passage
b) too much fuel - carburettor or fuel injection system supplying
too much fuel
c) too little air or too much fuel - engine control system -
vacuum hoses, sensors (eg exhaust oxygen, temperature, air flow),
computer, actuators (eg fuel metering solenoid, air metering
solenoids), wires and connections (control system voltages are so
low that small resistances from dirty or loose connections make a
big difference), the computer uses the input from the sensors to
send signals to the actuators to keep the air/fuel mixture at the
optimum for power, fuel efficiency, and low emissions.
d) too little air in exhaust system - restricted outside air feed
to converter (eg air pump or pulse air system - hoses, electrical
connections, valve, pump, drive belt, sensors)
2. HC (hydrocarbons, ie unburned fuel) too high.
causes:
a) not enough oxygen in combustion to burn all the fuel, or too
much fuel (mixture too rich), so excess fuel blows out exhaust.
b) too much oxygen in combustion or too little fuel (mixture too
lean) for uninterrupted combustion (engine misses), so unburned
c) sparkplugs not firing properly to ignite air/fuel mixture
(ignition system), so unburned fuel blows out exhaust.
d) combustion chamber too cold for complete combustion, so
e) combustion chamber hot spots preventing complete combustion,
f) not enough air (oxygen) in exhaust system to convert HC to H2O
and CO2.
g) faulty catalytic converter.
note that HC in exhaust can combine with S (sulphur) from fuel to
produce rotten egg smell.
look for:
a) mixture too rich - see a,b,c in CO section above. note that if
HC is too high but CO is okay then the problem is not a rich
mixture.
b) too much oxygen in combustion - leaks of air (hoses, gaskets)
and routing of hoses into intake manifold, leaks in EGR and PCV
valves
c) too little fuel - dirt in fuel/filtre/tank/lines, leaks in
fuel lines or connections, weak fuel pump, - mechnical problems
in carburettor (dirty valves or passages or linkages, worn parts
or gaskets) or fuel injection system
d) too much air or too little fuel - computer not mixing air and
fuel properly (see c in CO section above)
d) ignition system - sparkplugs fouled (type of fouling may
indicate problem), poor contact or insulation in high voltage
ignition wires or in distributor (cap, rotor), poor contact in
coil wires, low voltage in charging system (alternator,
regulator), faulty transistorized ignition control module
e) combustion chamber too cold - sticking EGR valve or sitcking
cylinder exhaust valve or bad cylinder valve timming letting
"cooler" exhaust gas into the combustion chamber.
f) combustion chamber hot spots - bits of junk (dirt, carbon) or
nicked or burned metal parts glowing red hot in combustion
chamber and igniting air/fuel mixture (engine misses) - can use
chemical cleaner in combustion chamber or take engine out on the
highway or both to burn off junk - overhaul engine to remove
nicked or burned metal parts or hardened junk
g) too little air in exhaust system - see d in CO section above.
3. NOx (oxides of nitrogen) too high:
causes:
a) too much heat in combustion chamber - air contains about 78%
N2 (nitrogen gas) which becomes chemically unstable above 2500
def F and combines with O2 (oxygen, making up about 21% of air)
to form NO which, released into the atmosphere, forms NO2 which
in the presence of sunlight combines with HC (hydrocarbons) to
form smog. note that NOx only happens when engine is under load
(car at crusing speed on road or rollers).
b) too much CO in exhaust (CO enhances the conversion of NO to
NO2).
look for:
a) too much heat in combustion chamber - the EGR system or the
valve timing is used to bring exhaust gas back into the
combustion chamber to cool it off when the engine is hot under
load at cruising speed - check the EGR system valves, solenoids,
wiring, hoses - if the car does not have an EGR system check
valve timing - (engine cooling (water) and lubricating (oil)
systems may have some effect on combustion chamber temperature?)
b) computerized engine control system - adjusts engine operation
to minimize emissions (see c in CO section above).
sources:
"Automechanics" (Prentice-Hall, 1988)
"Import Car Manual 1983-1990" (Chilton, 1989)
