UTKarmann_Ghia's Avatar
Send a message via Yahoo to UTKarmann_Ghia
Question Can your engine run too coo?
Pat S and I were talking about his engine temps and he was saying that with his new cooling system, he hadn't seen his engine temps go over 180. Although that seems great, I've heard a contradicting view of this. A local P-car mechanic said that the oil temps should get to about 210 to burn off any extra condensation.
Does this make sense to anybody? Why would a Porsche have any more of a chance to build up condensation that other cars? Is 180 truely bliss?
This is the same wrench who said I needed a bigger, front-mounted cooler if I wanted temps under 250
Matt
'82 911SC Targa!
Old 10-15-2003, 08:46 AM
IROC's Avatar
Actually, condensation will "burn off" or evaporate at temps below 212 degrees F. Just because the water in the oil isn't boiling, doesn't mean it's not evaporating.
The 2.7 that was in my car (before the 3.2) never ran over 180F on the street and I am convinced that this low operating temp was a major factor in it's longevity. The 3.2 in my car now doesn't run any hotter than 180-190F and I like it that way.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 10-15-2003, 08:55 AM
Rick Lee's Avatar
Well, if it's too low, that could mean other problems - like a stuck gauge, bad temp. sensor or even a rich mixture. But 180 sounds nice to me.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-15-2003, 09:02 AM
drag racing the short bus
dd74's Avatar
I agree. My 3.0 w/o external cooler rarely rises above 180 even on the hardest of drives in the hottest of L.A. days. I don't believe Porsche engines have a desired temperature in which they operate at an optimum. In fact, I've had two temperature sensors installed, and with both, the readings were the same.
Any engine that hovers around 180 and below is most probably a very happy engine.
The Terror of Tiny Town
Old 10-15-2003, 09:25 AM
Ok, well my car runs 210 pretty much, 220 on warm days. But the ext tstat (brand new) opens a bit late, somewhere over 200 (said 90C on the tstat) and I can feel the lines getting warm around 205-210.
Is there anything you can do about this? Maybe an aftermarket tstat which opens sooner? Maybe around the same time as the internal?
So is Gruppe B better or worse than Gruppe A?
Matt
'82 911SC Targa!
Old 10-15-2003, 10:14 AM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
I believe that the average optimum operating temp of synthetic oil is like 160F to 300F. If an air cooled engine doesn't like high temps, but 180-200 is still well above the oil's optimum temp beginning i'd say your in the sweet spot.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 10-15-2003, 10:37 AM
I asked the same question about my 930 engine after installing a big Setrab cooler. It just sits at 180.
The consensus was to consider myself lucky and not worry about it. That's a lot easier than trying to fix it.
Old 10-15-2003, 10:53 AM
Ho Hum 74's Avatar
Good question. I recently fitted an external 70 row (big mother) cooler in my IROC spoiler. I have a Mocal 180 degree thermostat. My car used to always run at 180 degrees WITHOUT an external cooler? Can this be? The PO suggested he fitted a pulley on the engine that made it run the engine cooler (fan speed increased? - who knows.)
Anyway, after fitting the cooler my car will not run over 120 degrees!! WTF? I did take it on the track and it went to 180 degrees but I have NEVER seen more than 120 the street.
I am seriously thinking my guage is not reading correct.
Thoughts?
Old 10-15-2003, 11:28 AM
1fastredsc's Avatar
It sounds like your thermostat is stuck open. The reason why 180 is a goal is because 180 is when the internal thermo opens up. If it's stuck open, you'll never get up to operating temp. You may want to check the electrical first, like the gauge, sender, wire that connects to it, stuff like that. After checking those things out, then attack anything mechanical, such as thermostats.
2007 Mazda 3 hatch
Old 10-15-2003, 12:00 PM
Ho Hum 74's Avatar
1fastredsc
Thanks, I will check the thermostat but there is one thing you should know about the Mocal thermostat:
It is an H configuration and the cross member is always open below 180 degrees. This means (as it was explained to me) that the oil would prefer to go through the H configuration cross member and back to the engine instead of going to the cooler. When it reaches 180 degrees the cross section closes up and forces the oil to make the trip to the cooler.
I can't understand what's going on here unless it is stuck in the closed condition.
What is the ramificaiton of not getting the internal thermostat to open up?
Just after I installed the cooler my number 3 big end rod bearing failed at the track. The oil temp went to about 180. I did about ten laps and the rod started knocking. I'm rebuilding the engine as we speak.
Thanks for the insight.
Tristan
Old 10-15-2003, 12:07 PM
Pat S's Avatar
I ran my engine without the external cooler at first after my rebuild to avoid getting all the metal from the first couple runs in the cooler. I hit about 220 or so. I then hooked up the 40 row mocal and as soon as the mocal termostat opened at 180, that's where my gauge stopped. It was very cool
Anyway I boil tested my internal thermo and it starts to open at just about 185 and is fully open about 190. Is there a problem if the external opens before the internal? I can't imagine there would be any problem, I mean after all the first 5-10 minutes of every drive would be too cool to open the cooler anyway right?
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 10-15-2003, 04:30 PM
