disband
the bad news 1st, clutch
what can i expect to pay for a clutch replace on an sc? (hands covering ears, and flinching)
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Blockchain Tech Inventor
If done correctly by a reputable shop - $1400 - $1600
A Mean Green Lifted 1972 C10 Long live the king! |
How difficult is it to do the job yourself?
1984 Targa |
This is a pretty easy job. There are some things you need to disconnect, and you have to be able to jack the car up pretty high, but it's not hard. There is surprisingly few connections tethering the engine to the chassis on a 911!
Plus, it's a good chance to really clean things up in the engine bay while the engine is out. There are tons of posts and some articles on this site about removing the engine and changing the clutch. |
If you have the means (garage, tools, time, and energy), I recommend you do it yourself. Of course, having a shop do it will be a lot quicker, but they won't go through the detail of cleaning every nook and cranny, addressing minor leaks, and working on other 'while you're in there' issues. The bulk of the work is in the engine/trans removal and installation. PM me your location if you're up for the job. If you're close enough, I'll help out where I can.
Eugene (Formerly) at Pelican Parts Pelican's E-Commerce Guy, 2003-2011 2001 330i Sport 1983 911SC Coupe (sold) |
SCWDP- Shock and Awe Dept
The hardest part would be the engine drop, great time to learn. Invite some guys over and feed them Beer, it will go quick and everybody will learn something. Worked for me.
You will also save a lot of money.
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
Funny... three of us said basically the same thing at the same time.
Irrationally exuberant
Easy job. My first automotive project was changing the brake pads in my VW Rabbit. My 2nd project was doing the clutch in my 911. It's that easy.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Another vote for DIY clutch job. I was a total know-nothing and DIY'ed my G50 clutch update. Made a lot of great friends, saved a lot of money and learned an incredible amount. Now I'm fearless!
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
How much are the parts?
1984 Targa |
Yeah dude, if you can manage to do it yourself it should save you about 1k. So if you needed an incentive to conquer your fear, maybe frugalness will do it
2007 Mazda 3 hatch 1972 Porsche 914 roller with plenty of holes to fix
I'd say plan on at least $500 in parts and another $200 if you need a new flywheel. Then, of course, there are all the "while you're in there" temptations.
Assuming no serious damage, can the flywheel just be resurfaced, or should it be replaced?
1984 Targa |
You should have it looked at by a pro. Serious may not look serious to the untrained eye. I dunno if you can have them resurfaced. For a lousy $150-$200 for a new one, I wouldn't cut corners here.
If you want to resurface it it must be measured for thinkness, there's a factory spec on how far it can wear, just like the brake rotors. Past that spec and you can't cut it down anymore.
If your there on your own (saving money), spend some of the savings on a lightwieght flywheel and pressure plate. Do the return helper spring and the throwout bearing, even if it's "good" maybe even the helper at the pedal.
As the others have said, dropping the engine is the hardest part, the rest is easy, other than some awkwardness under the car. See if you know anybody that knows someone with a lift. Dropping an engine with jack stands is a PITA, but doable. Your better off doing ramps.
GruppeB #935 84 Carrera Targa B.A.S.T.A.R.D. (for sale) 82 SC RSR Project (on ebay) 95 Dodge Ram 2500 03 Toyota 4runner |
While you are in there...
Check/replace the shifting bushings Clean, Clean, Clean... Check the engine tin rubber seals. Be sure they go around the tin correctly. Replace the oil pressure switch Replace the clutch cable Replace the rear main seal Check hoses to make sure they are not brittle Don't forget to get the ring gear off the old pressure plate Replace the TO bearing guide tube Replace the C spring and replace the 2 small bearings, washers and oring in that assembly
'75 914-6 3.2 (Track Car) '81 SC 3.6 (Beast) '993 Cab (Almost Done Restoring) |
