Well not the whole car ..... I was recently converting my 84 AC from R18 to R134. I was adding some freon from the rear and everything was going fine when I noticed that the AC clutch had dis-ingaged. I thought that the car inside temp had reached a normal level so I opened the door to check the thermostst and discovered the interior was filled with white smoke! (electrical smell) I just purchased this car and still learning much about it. It seams like it has fans everywhere. Can anyone tell me which fan may have gone up in smoke? PS 1) The fan from the dash slider is still working, the fan from the defrost switch (0,1,2,3) is not comming on. 2) I did hear the fan sqeeling in the cab when I first started working on the AC
Jeff T. 84 911 Targa |
Super Moderator
There is a fan in the front trunk that works with the A/C and seems prone to problems. It's right next to the battery.
Toxic
Possibly the evap fan, located inside the smugglers box.
If the clutch disengaged, the evap could of frozen up.
Bruce 88 Carrera Coupe, 12 Dodge Ram Hemi, 69 Barracuda Fastback, 68 Barracuda Convertible 5spd The only substitute for cubic inches is cubic dollar$. |
Thread Killer
I would guess the evaporator fan as well if you had smoke in the cabin and not from under the front of the car.
Seadweller here on the forum put together an EXCELLENT technical guide for replacing the motor. You can contact him through the forum, or if you want to send me a PM or email (with email address) I'll send his article to you.
Allen '85 911 Coupe '75 BMW 2002 '02 Ducati Monster 900ie '18 GMC Sierra Denali 6.2L 4wd |
Hey Allen,
My E-Mail is My84Porsche@AOL.com I would really appreciate the info on replacing the fan in the smuggler box.
Thread Killer
You have email!
There's a factory recommended upgrade to add a fuse for this fan. I've seen the damage that can be done if that thing starts burning...not pretty and not cheap.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Thread Killer
88911coupe,
Interesting, and probably a good idea. Do you have the amperage of the fuse that is supposed to be added?
Senior Member
Also could be one or both of the two fans by your feet. Have had these go and smoke up the interior.
Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
i would pull off the carpeted kick panels and check both footwell fans. they squeel, like you heard, and next they burn up.
Thanks for all the help. So far I found the fan in the smugglers box was frose up. It had blown the 25A fuse. The replacemet was difficult but I got it done. The tip by Teutonics and article by Seadweller was priceless. The only thing I would add to his list of tools is a set of very long needel nose pliers. It appers, I have other fans out as well. So far the front AC fan is also bad (burned open) and still looking at the other fans. As best I can tell the car has a total of 6 fans. 1. Main blower 2. Left heat foorwell. 3. Right heat footwell 4. Engine heat blower. 5. AC blower in smuggler box. 6. AC evaporator blower at front bumper. This is getting expensive!
