Racer
preston_brown's Avatar
Question easiest access to reverse light wire
I just got the Harman Kardon TrafficPro (really, a nice Becker CD Receiver/navigation system combo from Europe). Hookup hasn't been too difficult on my 87 Carrera, I tapped into the GPS/Speedometer for speed sensing, and the ash tray light for illumination cue, because these wires aren't provided in the regular stereo harness. The only wire I still need to hook up for GPS functionality is Reverse. I need to tap into either the reverse light, or the reverse light switch. Same circuit of course. Not sure where is the most accessible/easy to run a wire into the cabin from.
Can someone provide me with some hints? Like, does the wire run somewhere in the front trunk that I can tap into?
Preston Brown
Street: 2009 911 Carrera S Coupe | 2015 Cayenne S | 1995 Audi ÜrS6 (unicorn)
1965 356 C Coupe | 2010 F250 (support vehicle)
Race: 1994 964 GT2/1 | Various 944s | 2016 Superlite SLC | 2007 997 Carrera
Old 10-22-2003, 07:15 PM
jakermc's Avatar
The reverse light wire runs from the transmission to the light assembly at the rear of the vehicle. If you were liying on your back under the car, you'll see the wire run into a connector on the left (passenger) side of the transmission.
Once tapping in, you could try running the wire into the cabin the same way I ran the RPM sensor into my DL-90 unit. On the drivers side near the bottom of the rear seat, there is large tube that runs through a hole from the interior of the car to the engine compartment. I used this same hole to run the wire into the cabin, under the carpeting, and up to the dash area. There may be a more elegant way to do this, but this sure was easy.
1983 911 3.6L - NASA GTS-3 class
1998 Boxster - PCA SpecBoxster, NASA GTS-2
2003 996X51 - NASA GTS-4, PCA GTB
2003 996 Carrera 2 Coupe
2003 Ferrari 575M
Old 10-23-2003, 05:35 AM
