Lead substitue
the original owner said to use lead substitue but since tha heads are aluminum arent there steel inserts for the valves or is this for the valve guides and if this is good should you allways use it? but wont the lead substitue gunk up your injectors, regulators and anything else ????????????????
Old 11-15-2003, 06:16 PM
what year is your car?
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 11-15-2003, 09:52 PM
1977 2.7
1983 911SC
1977 911S "parting out"
Old 11-15-2003, 10:16 PM
Mikkel
Guest
Posts: n/a
US or Euro model?
I must admit that I don't know about 2,7s, but I can tell that Euro 1984 3,2s need lead replacement. 85s and on don't.
Old 11-15-2003, 11:50 PM
Irrationally exuberant
ChrisBennet's Avatar
Leaded gas in unnecessary. Porsche has been using hardened valve seats since some time in the 60's I think. You definately do not need leaded gas for any 3.2. Lead will destroy O2 sensors and cat converters.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-16-2003, 02:50 AM
Mikkel
Guest
Posts: n/a
Stef Scheepers who once attented this homepage did me a favour and asked one of his collegues in the engine department at Porsche Weissach if I should add lead replacement to the unleaded fuel in my euro 84 Carrera. The answer was yes.
Later I wrote an official letter to the Porsche Costumer service department asking the same question. I got the same answer: yes use lead replacement on a euro 84 Carrera!
Top ends on an 84 euro Carrera are not the same as 85 and on euro Carreras. That was what they told me both times.
Until I get an official message directly from Porsche AG not to use lead replacement I'll use lead replacement.
Old 11-16-2003, 05:54 AM
I've heard of using marvel mystery oil but it is a mystery to me....
1979 911 SC Targa
Old 11-16-2003, 06:58 AM
That is the first time I'd ever heard that. Thanks for the info. That is really strange though.
-Chris
Old 11-16-2003, 07:32 AM
Mikkel
Guest
Posts: n/a
It may not make any big difference and it may even be a waste of money to use lead substitute, but if the people at the factory say so I'll use it. The German that I bought my car from used the exact same substitute (Castrol Systemreiniger TBE Benzinzusatz). He was told by the workshop foreman at Porsche Zentrum Braunschweig (an official dealer) to use it. German fans discuss this subject lead/no lead too and seems to be devided in 2 camps. I'm not the only one who has a written message from Porsche AG that the use of lead substitute is recommended on euro 84 models. 85s and on have different top ends and thus don't need substitute it is said.
I just want to play safe and I'm no expert.
Old 11-16-2003, 09:39 AM
I'd like some defintive answer as to the "top-end" differences on 84 vs later 3.2 Carreras. Also...if so, whether it only applies to ROW or USA spec cars.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 11-16-2003, 03:08 PM
I would recommend driving lots and lots of miles so you can get a valve job done and avoid having to use lead.
-Chris
Old 11-16-2003, 05:54 PM
350HP930's Avatar
Chris' initial post about hardened steel valve seats is correct.
I would recommend not to let the hearsay of people who are likely misinformed let you go through the hassle of adding something to your fuel that is also a nasty oil contaminant.
Old 11-16-2003, 06:50 PM
