Best audio for cab's?
OK, another poll...
I will be receiving my 83 cab soon (hopefully)... what in your humble opinions is the best audio setup for a 911 cab? |
I have Infinity Kappa components for 'BOTH' front and back. Behind my seat is a self-powered Inifinity Basslink; for head unit, I have a non-powered Clarion; head unit and and the 2 component sets are driven by a Precision Power amp.
With the top down, I can still enjoy the muzak at high speed (even with SSI and early exhaust! One day, I'll try Dynos. p.s., I emailed a pelican member who used to mess around with custom speaker setup. He claims that Dynos 'were' excellent; so that deferred me from purchasing them for now. |
With your Basslink in the back, do you worry about your car getting broken into?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
might be anal,but I would like to attempt to keep as close to original as possible, i.e. using blaupunkt. I had one in my IROC years ago and always liked the sound. I would like to used a setup with tape in head unit adn cd controller for a changer mounted somewhere else?
Shane - 1984 928S |
With the top up, the unit is barely noticeable. 2nd, I figure if a punk wants to break in, they will break into your car. My car is a daily driver, but I DO PAY ATTENTION TO WHERE I PARK.
Stories I have heard: 1. Someone stole a 'radio shack brand' radio, which was worth probably $20.00 --- go figure! 2. a Doctor left the office and headed for his reserved parking. From a distance, he could see his space empty. He started shaking his head as he thought he had parked somewhere else. Being definite that he had parked his car in his reserved parking, he continued walking. Guess what he found in the middle of his parking space? The steering wheel of his car with the 'gorilla bar' still installed!!!. . Apparently, the thief came with his own wheel, uncrewed the factory wheel, and drove off. Guess it was quicker for the thief to uncrew the wheel vs. hacksawing a portion of it.
Do you have any pics of the mount? I'm short so I figure I could stick it behind my seat.
I am 5'9" at 160 lbs.
I'll take pics this weekend. |
Thanks.
I have an '83 Cab and I will try to post th elinks of my Basslink and amp that I have in my trunk - less chance some knucklehead will try to steal it! I have some old 5 1/4" Alpine speakers that need replaced, but in their day, with the amp, were more than enough!
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Nak head unit
Diamond Audio component speakers (front & rear) Boston Accoustic 8" sub in a custom made box (the "snout") A/D/S amp Precision Power amp (for subwoofer) As Robin Williams says in Good Morning Vietnam, "just play it loud"
C.H. Boost Addiction - honestly, I have it under control 1989 911 Turbo Cabriolet Mods include: Kokeln IC, GHL Headers, Hooligan muffler, Modified K27 7200, BL WUR, LC-1 & XD-16, Bilstein Sports (4), TRG sway bars, Oversize torsion bars, Strut brace |
MBruns for President
I have owned cabriolets through out the years - I have had 3 broken into at one point or another. Two slashed tops (once when the door was unlocked) = one busted window. One pryed open glove box (that wasn't locked)
I no longer lock my car and I refrained from putting an expensive stereo in my car - I have a stock looking blapunkt I got from Sams club for under $100. It's just fine in the car, nice sound - even with the top down. Now I have the 3.4 - it tends to have better music to that available on the radio/cd...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
A very high end set of headphones.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Still Doin Time
Mcintosh head unit / amp
Dynaudio 340 3-way system in the front doors (6.5/4/2) Dynaudio 10" sub mounted to the pass false floor; facing rearwards -not visible Time consuming and $$$
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Czar of C.R.A.P.
First thing I did when I got my cab is put in a better stereo. The second thing I did was turn if off......
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
Used Up User
After ignoring for 2 years I just ordered Focal 165V1 Kits (2 way component speakers) + one of their new FP2.75 (2 x 75w RMS) amps for a door install.
Dominic Baker (designer of the Utopia BE series) gave me some sage advice: "What's going to make the biggest difference to the sound is the door build: You'll need to remove the door trim and then cover the outside skin of the door with dynamat. The inner frame of the door which supports the trim will normally have lots of punched out holes in it - these can be sealed with a piece of dynamat on either side. You'll need to use some foam to squeeze behind the door mechanism cables to stop them rattling. Finally, make sure that you have a good, solid, air tight mounting between driver and door. Basically what you are aiming for is to turn your door into a sealed, damped loudspeaker enclosure. If you can achieve this, you should have plenty of bass etc without need for a sub. Would be worth running decent cables from the amp to the speakers too." Ian
'87 Carrera Cab ----- “Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.” A. Einstein ----- |
SSI's and M+K
'79 930/934 replica 80 RSR-look(Now in Sicily) 914/6 2.7 (Projekt 908/3) 1965 Karman Ghia-Class winner 2007 Carrera Panamericana/Ducati 900ss/GhezziBrian STW D-Zug Produkte/D-Zug.com |
