Send a message via AIM to dtfastbear Send a message via Yahoo to dtfastbear
Will an 87-89 3.2 bolt right up to a 915?
Having recently cratered the 3.2 engine in my '86 Carrera, I'm in the market for a good used 3.2. My question is, can I safely look for any engine between 84-89? Or, will there be some sort of retrofit necessary for an 87-89 3.2 designed to fit the G50 if I want to run a 915?
I will be using my own 915 tranny which I just had rebuilt only a couple weeks ago...
Thanks!
Dean
'86 Carrera cab (euro)
Spec Miata
Old 10-27-2003, 07:21 AM
Irrationally exuberant
ChrisBennet's Avatar
I have an '89 motor on my '86 (915). The motors are the same, just the flywheels are different. If you put an '87-89 motor in you '86 you will want to adjust the base idle to match your pre-87 DME.
'84-86 idle at 800rpm
'87-89 idle at 880rpm
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 10-27-2003, 07:26 AM
jtf914's Avatar
When installing marcesq's 3.2 into his 77 911 we found that the mounting studs were longer for a 3.2 equipped with a G50. We had to pull the studs from his 2.7 and install them on the new 3.2, in order to attach the 915.
-Justin
My Dyno run:
http://www.youtube.com/watch?v=9i8E51PmUgw&sns=em
Old 10-28-2003, 08:57 AM
Rick Lee's Avatar
Yes, Justin is right. Don't forget those case-tranny studs. You can just double-nut them in and out. I think Marc had to dremel part of his bell housing to accept the sensors, but that should be a non-issue on a 915 that already had a DME 3.2 on it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-28-2003, 09:19 AM
