Friend of Warren
'86 Carrera Rear Bumper
I have decided that I will not be putting back on the big, heavy rubber pads or the rub strips on my rear bumper after the engine rebuild. So I need to fill those holes up. The bumper is aluminum and I will be repainting it. My initial thoughts were to just rough up the holes with sandpaper and fill them with JB Weld. Any better ideas?
Kurt V
Old 10-29-2003, 11:38 AM
KTL KTL is online now
Schleprock
KTL's Avatar
Plastic plugs:
They're just like these in the solid nylon black, locking variety:
I got them at Ace Hardware in the fasteners aisle, per the recommendation of my buddy Mark. Painted them with some touch up paint and you'd swear they were made for the car!
Kevin L
'86 Carrera "Larry"
Old 10-29-2003, 12:03 PM
Friend of Warren
Kevin, your bumper is what gave me the idea, but if I fill the holes in it will be completely smooth when I paint it. If I use the plugs then I will have even more than you do because I also took off the black rub strips.
Kurt V
Old 10-29-2003, 12:15 PM
Schleprock
KTL's Avatar
I know what you mean Kurt. I wanted to fill in the holes too. But if you remove the rubber strip, what will cover the big flat washers and the locknuts for fastening the bumper? This is why I kept the rubber strip.
My buddy Mark has a black car, and the lack of the strip doesn't seem to stand out as much. On my car it looks like a work-in-progress without the strip.
Kevin L
'86 Carrera "Larry"
Old 10-29-2003, 12:25 PM
Friend of Warren
Damn, good point. Hadn't thought of that! Good thing I have this board to keep me straight!
Kurt V
Old 10-29-2003, 12:35 PM
So how do you remove the big ol bumper stops? Easy or difficult? Instructions? Thanks
1980 911SC Targa 3.6L
Old 10-29-2003, 12:39 PM
Friend of Warren
They are just bolted on behind the bumper. Assuming the nuts aren't rusted, just unscrew the nuts and pull the pads off. My pads were stuck to the bumper and I needed to use a rubber mallet to break them loose. Took about 10 minutes start to finish.
Kurt V
Old 10-29-2003, 12:42 PM
85Gold's Avatar
Glad I had my rubber pads last weekend when the car behind me decided to get a real close up view of my Whaletail at a stop light. We were both stopped and she just crept up until she hit me!! Big ugly pads = no damage. Just another take on removal.
Peter
2005 GT3 Black SCCA Solo 2 SS
1999 M Coupe SCCA SM2
2001 Mazda Miata (Wife's Ride)
2005 F150 FX4 + Trailex
Old 10-29-2003, 01:59 PM
85Gold's Avatar
I am glad I had my big UGLY pads last weekend when a car decided it wanted to get a real close look at my Whaletail at a stoplight. We were both stopped and she just drifted forward and HIT me in the rear. BIG UGLY PADS = no damage. Just another take on removal.
Peter
Old 10-29-2003, 02:08 PM
I just removed mine and the black rubber strips. I took the bumper shocks off and had them drilled out then I used carriage bolts to hold the bumper in place. I was only able to use a total of 2 bolts because of the curve of the bumper but it seems to be holding well. Car goes in for paint this winter so I was just going to let the body shop fill in the holes.
1978 widebody targa
Old 10-29-2003, 02:36 PM
whats the weight savings from removing bumpers? 15lbs maybe? sounds like it's primarily for looks.
Old 10-29-2003, 02:50 PM
mm86911's Avatar
Two words - RUF Style
Mike - PBG, FL
'14 958 Cayenne GTS
'05 997 C2 - SOLD
'79 911 SC Widebody PCA, NASA, PBOC - SOLD
2004 NASA-SE GTS4 Champ, 2005 + 2007 NASA-SE GTS3
Old 10-29-2003, 03:01 PM
With RUF bunpers you lose the accordians and some of us like those!
1978 widebody targa
Old 10-29-2003, 03:34 PM
Friend of Warren
Yes it is mainly for looks. And yes RUF bumpers are nice, but this way I don't have to buy another bumper.
Kurt V
Old 10-29-2003, 05:38 PM
Jeff Alton's Avatar
I had mine welded by a local race car builder and then I faired them sanded and painted the bumper.
Jeff
www.turn3autosport.com
Old 10-29-2003, 08:21 PM
I stripped down to bare metal, then used body filler and repainted. I'm using some plastic caps from Ace over the 4 nuts while I figure out what I want to do about them. It looks a little goofy, but so does the rest of the car
Old 10-29-2003, 08:42 PM
Hey Kevin-
From the picture of your rear bumper it looks like you've modified the ends of the rubber strips. Did you put the chamfers on the ends nearest the license plate?
I'm not at home (away on business) so I can't check my SC, but I thought mine butted up flush with the rubber bumpers.
If you did, how'd you do it and get it to look so nicely done?
Thanks,
CB
78 SC
Chris Bunker
78 SC
Old 10-30-2003, 07:55 AM
Hey Cowtown...
why not fab some sort of "D" ring that mounts to the bolts that stick out...like a pull-eye for the tow truck that pulls you out of the sand on a racetrack. Maybe even paint it red.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 10-30-2003, 09:28 AM
Schleprock
KTL's Avatar
Originally posted by Chris Bunker
Hey Kevin-
Thanks,
CB
78 SC
Those strips are shaped as they were originally made as far as I know. The first time I pulled the bumper, they were tough to get off, so I don't think anybody modfied them? The shape looks original. One thing though. The ends don't sit down on the bumper completely flat. They stick out maybe 1/16"-1/8". Hardly noticeable though.
Good idea on the D-ring Wil.
Kevin L
'86 Carrera "Larry"
Old 10-30-2003, 10:32 AM
Former Options Trader !!!
What do you do for plate lights ?
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 10-30-2003, 11:35 AM
