Electronic Rust Prevention
Morning Guys
At the time of posting there is an active thread relating to rust prevention, which prompts this question... Recently I dropped into a local 4WD accessory shop and came across a device which is supposed to slow or prevent the formation of rust. I have noted the manufacture's web site for those with any interest. http://www.erps.com.au/index_erps.html Has anyone any experience with this or a similar product / system? Do they work? From the little I’ve read to date it would seem to have some merit… but then so did the cool collar. Regards,
Paul 1969 Porsche 911T 3.2 (Matching # engine safely in storage) 2021 AMG C43 2020 BMW X4 1979 Californian Moke |
I knew a guy that had a kilowatt transmitter rig in the trunk of his car (ham radio op).
The car was an old chevy...about 10-12 yrs old at the time....with no rust. I saw the same car about 10 yrs after that...still no rust and no body job according to the owner. So...perhaps large currents of power flowing through the chassis might help....but I am open to other thoughts on the subject. Bob
Bob Hutson |
Local TV show "Two Guys Garage" featured...
a product from this company http://www.counteractrust.com.
A mechanic uncle had a 1992 Nissan Pathfinder that had a similar system installed in it, he sold the truck back in '96. While he no longer owns it, the current owner still brings it his shop for service. After 11yrs of our salty winters, I gotta say it doesn't have a lick of rust on it. |
Personally, I am very skeptical. Check this tread.
Senior Member
I think these products work on the principles of Cathodic Protection. It's nothing new, and is used on all kinds of iron structures that need protection from corrosion. Common on structures such as bridges and offshore oil platforms, for example.
'81 SC Coupe "Blue Bomber" "Keep your eyes on the road, and your hands upon the wheel."- J.D.M. |
otherwise a zinc pencil in the water engine cooling system will lengthen the radiator life.. IF you check the pencil for condition yearly.. kinda like the zinc in your home hot water heater boiler..
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
For these systems to work, they require a conductive path. If you look at a boat, Only the parts below water are protected since they are constantly wet. The stuff above the water line corrodes.
i want one of those...
Location: formerly a grass shack in Hawaii, now Peoria, AZ
I'm not sure if the stuff works...my mom's got one in her '95 Villager, and there's a big patch of rust forming underneath the rear tailgate hinge. I'm not a believer...
Jeff '72 911 T Targa widebody VTK #111385 http://www.911vtk.com |
Now for long term storage, if done correctly, I think it could be made to work. http://www.corrosion-doctors.org/CP/Introduction.htm |
Information Junky
hmmm . .. doesn't the (highly active) battery supply plenty of sacrificial electrons ?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Unregistered
Total BS scam, works as well as the magnetic fuel line treater that improves mileage 50% and the tornado device that improves power and mileage 10%.
The factory coats the entire chassis with zinc, which acts as a sacrificial annode. The reason they coat the entire chassis is that it is necessary in order to protect the entire chassis. If it wasn't they would not spend the extra money to do it. If all it took was 2 bucks worth of electronic parts the car manufacturers of the world would be all over it. |
SCWDP- Shock and Awe Dept
Didn’t the Britts basically try the same thing by using the positive “ground” on cars?
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
boat mechanics have loads of fun removing exhaust systems from small boats due to electrolysis routinely. and the entire ground system are/it better be grounded thru the hull ......Ron
The positive ground arose from the fact that we (the british) use the current flow not the electron flow to describe the poles of a circuit.
With electron flow...the electrons flow from negative to positive...but with current flow...the current flows from positive to negative (earle morning for me...I hope I got that right). So...with british cars it was logical to ground the positive so that the current flow was from the chassis to the top pole of the battery (the negative in this case). Class dismissed...and there will be a test on Monday...LOL Bob
Bob Hutson |
Thanks for all the information. Looks like I’ll stick to my current sacrificial corrosion system – where my wallet gets lighter when rust appears.
Cheers
1968 911L 2004 Dodge Dakota SLT Plus |
I saw a long, flexable, needle like spray tip that was used to spray rust preventitive into hard to reach areas like rockers and window posts. So the question goes, since you can't get into such areas to clean before spraying what do you spray in there to keep it from rusting ? Zinc paint ?
I like them I drive them |
Information Junky
FWIW
The zinc, on and SC and such, doesn't just act as a sacrificial annode. (if that where the case, it would likely just be a block-o'zinc bolted down somewhere. . like on a ship) The thing is, by coating all the steel with zinc, the zinc protects it like self healing paint. If this 'paint' gets scratched it will form a 'scab' of oxide around the scratch. Theses oxides dont sluff off like the steel oxides do (rust). . . .self-passivation is a good thing
Czar of C.R.A.P.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
