H4 Light Conversion - am I missing something?
As an owner of a 911 for just over 4 weeks I find this board extremely helpful in picking up all sorts of knowledge. One of the threads I have been following has been the issue of upgrading to H4 lights. When I first drove my car at night I was horrified by the poor quality of range coming from the standard sealed beams so this weekend I purchased a RING kit of H4 conversion for £44. Took about an hour to fit as the ring that hold the light unit had to have the slots widened. I fitted 100/80 watt bulbs and as you would expect there is a tremendous improvement. My question is why are all the 'Porsche' kits I see advertised so expensive? I still have the clear glass to the headlamp units fitted.
Car is of 1965 vintage so are these fittings different? |
I'm not sure but those higher powered bulbs might be too much for the wiring.
Here's a usefull link >>>>>Look<<<<<
Chris - - - - - - - - - - - - - - - - - - - - - 1982 911 SC Hellblau Metalic - - - - - - - - - - - - - - - - - - - - - 1997 Boxster 986 2.5l |
Thanks for the tip. All my previous classic cars (Saabs) have all had their headlamps run via relays and it never occurred to me that Porsche would not do the same.
tbbuk: there are two H4 kits, one is a sealed beam US replacement (or non-US, for that matter). The other is the euro H4 housings.
The sealed beam kit is fairly inexpensive, the euro is 3-4x as much.
1968 911L 2004 Dodge Dakota SLT Plus |
Go Speedracer, go!
(ducking my head!)
1981 SC ROW Coupe |
Hella usually is the maker of the less expensive, US sealed beam replacements... Bosch makes the aero looking H4's at higher price.
---Wil Ferch ---
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Bosch H4 headlamps here in the UK are typically approx £85 each. Andy '69 911E------->R Last edited by andyjboy; 11-05-2003 at 09:21 AM.. |
Andy,
it sounds like tbbuk's car has the USA-production '65 thru '67 Hella headlanp assemblies, rather than the European assemblies using a Type 'A' incandescent bulb of 45/40 Watts ... and that he purchased H4 'conversion' assemblies using separate reflector/lens and H4 bulbs. Those Hella assemblies are quite nice in appearance, and almost identical to '49 - '66 VW Beetle and 356 headlamps for USA cars!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Warren is right and he has answered my original question as to why some of the official kits are so expensive. I could have done it cheaper if I had bought from
http://www.classic-car-accessories.co.uk/acatalog/Home_LIGHTS_5.html where the headlight unit is only some £11.35 each inc tax. The bulbs I already had in stock. NB this site seems to take a long time to lead. |
