-   -   Pin out for engine connector (http://forums.pelicanparts.com/porsche-911-technical-forum/134002-pin-out-engine-connector.html)
Randy Webb 11-01-2003 03:51 PM
I have a question about the big rectangular multi-wire connector that runs from the engine to the car -- is the pin out the same for a 1986 as for a 1973? I have a 1986 engine that I want to put into my '73 coupe (no electronic brains, etc. it's carburetted now but still uses some of those wires).
Raynald 11-01-2003 04:17 PM
14 pins
hello Randy,
i hope this can help you !http://forums.pelicanparts.com/uploa...1067732268.jpg
Randy Webb 11-01-2003 06:00 PM
Thanks Raynald, What engine is that for? and is it from a PAG manual?
Raynald 11-01-2003 06:25 PM
it is for a 1974 cis, i received it from another pelican member 2 years ago...
now i have webers and some wires i don't use...
Early_S_Man 11-01-2003 07:38 PM
Randy,
It doesn't seem very likely that a diagram from an '86 would apply, or be of any use ...
What kind of distributor does the engine have on it, and what kind of ignition? Was it actually running before you got the engine?
Seems as though you will have to trace the wiring and draw a diagram ... break it down into subsystems: alternator, ignition, starter, gauges, etc.
alan911 11-02-2003 08:57 AM
It's from my '77. Probably o.k. for 72-78.
Also, it's FROM the ENGINE side of the connector not the body side.
I doubt it would be indicitive of the engine side of an '86 as Early says.
