Randy Webb's Avatar
Pin out for engine connector
I have a question about the big rectangular multi-wire connector that runs from the engine to the car -- is the pin out the same for a 1986 as for a 1973? I have a 1986 engine that I want to put into my '73 coupe (no electronic brains, etc. it's carburetted now but still uses some of those wires).
Old 11-01-2003, 03:51 PM
Raynald's Avatar
14 pins
hello Randy,
i hope this can help you !
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 11-01-2003, 04:17 PM
Randy Webb's Avatar
Thanks Raynald, What engine is that for? and is it from a PAG manual?
Old 11-01-2003, 06:00 PM
Raynald's Avatar
it is for a 1974 cis, i received it from another pelican member 2 years ago...
now i have webers and some wires i don't use...
Old 11-01-2003, 06:25 PM
Early_S_Man's Avatar
Porsche Crest
Randy,
It doesn't seem very likely that a diagram from an '86 would apply, or be of any use ...
What kind of distributor does the engine have on it, and what kind of ignition? Was it actually running before you got the engine?
Seems as though you will have to trace the wiring and draw a diagram ... break it down into subsystems: alternator, ignition, starter, gauges, etc.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-01-2003, 07:38 PM
It's from my '77. Probably o.k. for 72-78.
Also, it's FROM the ENGINE side of the connector not the body side.
I doubt it would be indicitive of the engine side of an '86 as Early says.
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 11-02-2003, 08:57 AM
