JTO JTO is offline
Question Engine Miss Help
Hi Gang,
I did the diagnostics that a few of you suggested but the car continues to missfire. The miss seems to be coming from the passenger side of the engine. If I remove the plug wires systematically, only the driver's side wire removal appears to affect the idle quality. I have checked the passenger side wires for resistance and they all measured 6 OHMs. I changed the spark plugs to known good ones, and still the engine idles roughly and misses. The number five plug was wet when I pulled it, but then found number four wet later. If I rev the engine it smooths out past about half throttle but as soon as movement of the throttle stops, the engine begins to miss again. I am not saying that it runs normally as throttle opens, just better. The engine was running fine Thursday night when I parked it in the garage. Friday morning, all of this began.
I checked the injectors for flow and all seemed normal. I have put two bottles of Techron in the tank and run it on hwy to remove deposits. No improvement.
Any ideas? Thanks,
Troy
Troy
Past: 1975 911S Silver Anniversary-rebuilt and sublime.
Past: 1988 Carrera-backdated with a 3.6 and all the goodies.
Present: 2011 GMC 2500HD with the 6.0 & 4x4!, 2004 Toyota Sequoia (wife's)
Old 11-03-2003, 08:17 AM
JTO JTO is offline
i know there is the expertise out there to help me with this! I have to get it back on the road!
Thanks,
Troy
Troy
Old 11-03-2003, 09:32 AM
Otto's Avatar
idle
Change the intake manifold gaskets, and probably the intake boots.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 11-03-2003, 04:38 PM
JTO JTO is offline
Thanks Otto,
The motor is completely rebuilt last summer. The engine ran great one day and literally ran terrible the next morning, "missing". I replaced a bad injector o-ring but the car continues to miss. The carb cleaner test revealed no vacuum leaks.
Troy
Troy
Old 11-03-2003, 04:42 PM
Early_S_Man's Avatar
Porsche Crest
JTO,
You mean 6K, or 6000 Ohms, right?
Are the ignition wires factory, or aftermarket?
Are you saying only removing spark plug wires 1 - 3 ... has any effect on idle?
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-03-2003, 05:02 PM
I've been wondering what is a good baseline for replacing OEM ignition wires? My SC wires do arc a little in places & I mean only slightly. I've read threads of people describing a light show at night- mine is noticeable if I look carefully but not spectacular. Does this mean they should be replaced?
thanks
Old 11-03-2003, 05:45 PM
JTO JTO is offline
Warren,
It appears that the driver's side of the engine is getting good spark based on the fact that when I pulled the plug wires from this side, systematically, the engine idle dropped and the engine nearly died. When I did this test on the passenger's side, the rough idle did not change. In other words, it appears that the passenger side is getting intermitant spark. I also felt that the arc from the spark plug connector was weak and I could only get one or two arcs to jump to ground. On the driver's side, the spark would jump an inch.
Thanks,
Troy
Troy
Old 11-04-2003, 08:02 AM
