cab elec top problem
hi all,
my elec top isnt working,hoping for some suggestions please. i had to lower the roof manually. i pulled the switch and i have power at 1 of the 3 wires. when removing switch the 3 wires came of the switch. can anybody assist with wiring diagram for the 3 wires to the switch. should there only be power at 1 of the 3 wires. any suggestions of what to check next. thanks Dean |
THe center wire should be "hot", then the switch position determines which way the motors run.
Couple of things to check: Check the relay Make sure the microswitches on the transmission (Passenger side, drivers in UK\AUS) are not triggered - if the little "feet" get out of alignment and lits the upper switch, it cuts all power to the top. AFJuvat |
hi afjuvat,
so on the switch as long as the hot wire is centre pin the other 2 wires dont really matter,switch will operate around the wrong way if the other 2 wires are switched around. what do u mean about transmission ,where is it located exactly please. |
| All times are GMT -8. The time now is 06:17 AM. |
