Winter Projects..Not Honey do, P-Car do
Who's doing what over the winter? Me:
1.) rebuild A/C compressor, new dryer and recharge
2.) fix power window
3.) recarpet
4.) basic maintenance
Charles
88 Cab
Old 11-09-2003, 08:19 AM
1) Full suspension refresh
- new (used) torsions
- adjustable spring plate
- new koni's in the front to match the ones the PO put in the rear
- new bushings
- turbo tie rod kit
2) Rust chasing
- POR trunk. Its a big mess. Gas tank support is shot, but the tank isn't falling out. Getting someone to replace it is a spring task unless I find someone local who knows how to do it and wants to help for beer
- Examine some worrisome rust bubbles.
- Find a place that can color-match my paint, since I don't have a paint code.
- Touchup chips where the original white, or rust is peeking through
3) Some mechanical stuff
- Get temp gauge working
- If I'm feeling adventurous, drop engine, refresh tranny.
- Plan for a spring tuneup (adjust valves, clean and adjust carbs, see if I can fix the idle, etc)
4) Misc body stuff
- Replace windshield and rear window seals, quarter window seals, misc other seals.
- Upgrade rear lighting. Its spotty at best, and way too dim.
- Fix drivers window once and for all. Sometimes it goes up and down, sometimes it doesn't.
5) Spring planning.
- Find local shop who can fab a roll bar for the car assuming it'll be less than the crazy $900 they seem to be for the SWB based cars from tuner shops.
1968 911L
2004 Dodge Dakota SLT Plus
Old 11-09-2003, 08:30 AM
You have much longer winters than we do!
Charles
88 Cab
Charles
88 911 Cab
74 TR6
88 CRX Si
79 930 #632 (sold her and survived her)
Old 11-09-2003, 08:38 AM
Raynald's Avatar
winter...
Hello
for me this winter will be for small project, i will remplace all black trims for chrome, i have winter time for find part missing or if you have it for sale let me know ...
Ray
1960 356 BT-5 Aetna blue
1973 911 RS récréation
1960 VW panel Dove blue
1971 914 barn find !
Old 11-09-2003, 08:41 AM
EFI and center mounted oilcooler. And maybe shroud headers for heat
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 11-09-2003, 03:20 PM
efhughes3's Avatar
1. Recaros
2. RS carpet kit
3. Roll bar
4. Harnesses
5. A/C
My wish list in order. Everything but the A/C is probable.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 11-09-2003, 04:21 PM
n8marx's Avatar
Long enjoyable winter up here. Some projects are smaller than others.
1. Good buff job and many coats of wax
2. Polish/paint Fuchs
3. Adjust Valves
4. Rebuild Calipers (again)
5. Fix rattling window tracks
6. Fix rattling sunroof
7. Fix squeaky dash vent
8. Lube or replace clutch cable
9. Refurb Tachometer trim ring (got a dent)
10. Headlight relay kit and Euro H4s w/ High wattage bulbs
11. Replace rotor/cap/plug wires
12. New oil pressure sender
13. Design/build strut tower brace
14. Rebuild air cond. compressor and recharge system
15. Seine systems shift gate kit
16. New stereo (head unit. speakers, wiring)
17. Shocks?
Does Pelican sell a/ A/C compressor rebuild kit? Does anyone?
Nate
Gone: '86 Carrera coupe
Current: a $75 BMW 320i
Old 11-09-2003, 04:36 PM
1. Fix defrosters
2. Fix doorlocks
3. Fix sunroof.
4. New steering wheel w/ turbo tie
5. Fix/New rear sway bar
already removed my entire door panel and still cant see whats wrong with the freaking driver side door locks!! randomly works on and off!
-matt 86 911 Coupe
Old 11-09-2003, 05:03 PM
Alan Cottrill's Avatar
not much...
engine rebuild, already out and tore down.
remove all evidence of air conditioning.
big AL
'77 911
Old 11-09-2003, 05:28 PM
Zeke's Avatar
Re: Winter Projects..Not Honey do, P-Car do
Where do I start? Sigh
Old 11-09-2003, 05:46 PM
I have just started my project.
Remove engine and tranny, replace all of the dried and cracked stuff there is on a 20 yeart hat needs replaced and clean and detail engine compartment and underbody.
I have taken out my axles and taken apart my cv joints. the grease was really bad inside. I have read up on the things to do when the engine is out, hope i don't forget anything. I will add pics later.
I am leaning on taking my airconditioning completly out. Don't know yet, but it sure shows the engine off better and dosn't work anyway
bk
83 cab
Old 11-09-2003, 06:03 PM
Senior Member
Leland Pate's Avatar
I'm just starting to put together a list.
It's gonna be fun!
Chief Architect and Mastermind,
SCWDP
Old 11-09-2003, 06:05 PM
clnilsen's Avatar
Hmm
1) Carerra Oil Cooler
2) Front Bumper Smile Strip Replace
3) Backdate Heating
4) New Seatbelts and brey krause fire extringuisher mount
5) Exhaust if I'm lucky... :-)
Chuck
1980 911 SC Targa *Sold!*
2003 Boxster
2013 Beetle Turbo cab
Old 11-09-2003, 06:08 PM
Pat S's Avatar
Project 1: Drive
Project 2: Drive more.
I spent my summer doing an unplanned rebuild. I plan to drive on every nice day I can this winter.
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
New halfs shafts, rear wheel bearings, new shorter studs to fit
1" spacer instead of 1 3/8" to be able to run 275x40 tire without the ocaasional chirp. PS I have made a tool to remove the rear
wheels bearings without removeing the swing arm, when I'm done I would either sell or rent it to anyone on this board.
Keith Epperly
Old 11-09-2003, 06:21 PM
Erakad's Avatar
Let's see:
1. Just fixed headlight washers
2. Rear window defroster
3. Fix power mirrors
4. Vent cables
5. Fix AC
6. 1 more hose for heater system
7. Oil Change
8. Valve adjust
9. Timinig adjust
10. Re-dye seats and door panels
11. Buff and Wax....buff and wax some more...then more
Rob
Black 1983
911 SC Coupe
Old 11-09-2003, 06:27 PM
Shaun @ Tru6's Avatar
84
- Fix wiper motor
- paint front and rear bumpers, duck tail, and if I ever get the rest of the interior back from Original Fit, that goes in too.
- interior light
- driver door hinge strengthener
69
- wire brush front trunk and underbody, then POR-15 the whole thing
- Momo Prototypo
- reset dash
71
- learn to weld
- cut rear quarters off
- weld in new front pan and rear longitudinals
- strip entire car (what's left)
- weld on SC quarters
- learn to paint
- paint car smoke blue
- Chuck's bearings on Carrera F/R suspension (powdercoat suspension)
- big bars (torsion and sway)
- all glass becomes plastic
- carbon front hood
- carbon R fenders
- glass S bumper
- carbon rear bumper
- carbon ducktail
- rollcage
- 3.2/915/oil lines with Chuck's big mouth install
- fuel cell
- seat and belts
- fire extinguisher
Tru6 Restoration & Design
Old 11-09-2003, 07:14 PM
geof33's Avatar
Most of my project is done... Pics soon...
Color sand, buff, buff, buff, polish, polish, wax.... (I'm really liking my Porter Cable variable buffer!!!!
Carrera side script
New steering wheel, rare momo martini two spoke...
Might redo my "new to me" Fuchs.
Relocate wiper reserviour.
corner balance/align
GruppeB #935
84 Carrera Targa B.A.S.T.A.R.D. (for sale)
82 SC RSR Project (on ebay)
95 Dodge Ram 2500
03 Toyota 4runner
Old 11-09-2003, 09:54 PM
