Gas Tank venting
Does anyone know how the 911 gas tanks are vented. I know about the carbon cannister. I need to know how air is vented INTO the tank as fuel is used.
As result of emissions inspection, I had to replace my gas cap. Unfortunately, the new cap seals the tank too well, so I get a strong vacuum as the tank empties. I think this is buckling the tank slightly, causing problems with my fuel guage sensor. Is there a diagram showing how the tank is vented? |
I'm off the hook.....
Did you keep the old cap?
Emissions vs. Collapsed tank..... hmmmmmm.
No, I don't sing. Based there for too long. |
Here's a sample of how they did it in 1970:
Certified Pre-Owned
Re: Gas Tank venting
-BG
'84 Carrera Coupe |
In college, I collapsed a gas tank in a Merc Marauder the first week that I-5 was open south of Modesto. As tank collapsed, it captured the sender at 1/3 reading. I couldn't believe the mileage I was getting until in the dark, it ran out of gas. 25 miles from anywhere, pre-cell phone era. My GF and I (totally in the darkness, not a light anywhere on the horizon) waitied by the car until someone came by. Took several hours to get a ride back with 5 gals of gas. Tank filled after 3 gallons. Non-vented cap had let fuel pump suck tank flat. GF insisted I did this to get her marooned for a make out session....... Ran out of gas, right.
Re: Re: Gas Tank venting
When I open the gas cap to fill the tank, there is a very strong air intake. I recently put in a new sensor and the mechanic had to actually press the tank bottom out a bit with a rod to fit the sensor. I am on my second new sensor now. I have also heard from automotive engineers that if and when the carbon cannisters and venting lines clog up over the years, it is not uncommon for tanks from american tanks to collapse a few millimeters from the vacuum. (I also foolishly threw away the old cap!). |
Will replacing the carbon cannister relieve some pressure? Or are there other venting lines I should check? |
I think I would find a vented gas cap until you get the vent system checked out.
Although it seems counter intuitive it really takes very little vacuum to collapse and buckle thin wall vessels especially of construction and aspect ratio typical of automotive fuel tanks. Without venting, a fuel pump or even thermal contraction of fuel and fuel vapors if the tank is sealed while hot and then cools significantly can produce enough vacuum to cause problems. Jim Sims
Chuck Moreland - elephantracing.com - vonnen.com |
Not to hijack but here is a question...
I have a 1973 with a 3.2 in it. I dont have the front charcoal canister anymore. The lines are disconnected on both ends. I do have the fender expansion tank. Do I need it with the 3.2???
Keeper of the Titanium Monkey 1975 911S (sold) 1973 911 w/3.2 (sold) 1983 911SC targa (sold) Looking for a 987.2 or 981 Cayman |
Being in both P-car worlds (water cooled and oil cooled) I could really use an air cooled Porsche clock.
(Word Count = 19; P-car content checked, Word "PORSCHE" found, line 1)
disband
did they keep the original porsche (500k post req) cap? if not why did'nt you drive around the corner and replace it?
let see, 10 words,,,, check
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
SCWDP- Shock and Awe Dept
You can get new a seal for the cap and it will pass smog w/ no problem, of course, you threw it away. Did you get a new factory one?
Ryan Williams, SCWDP '81 911SC Targa 3.6 '81 911SC Coupe 3.2 #811 '64 VW Camper Bus, lil' Blue |
I just replaced the gas cap on the 944. It has a feature where you can turn it a half turn, and it releases the pressure/vacuum. I think I got it at NAPA.
Unregistered
Check your cap, it probably has a large rubber o-ring on it. For the short term you could carefully remove the o-ring, voila, self venting cap.
Sammy! That's thinking outside the box! Us '80 911SC guys are known for that!
