Team California
speeder's Avatar
911SC windshield trim
Anyone have any tips on re-installing this? This does not appear to be a job for the short tempered, , in fact it seems impossible.
I put new w/s rubber in myself last night, (thanks Tyson for the tip, worked like a charm), I took some pics for a possible tech article if one does not already exist. Took a lot of prep work on the body to clean it up, hopefully solved my leaks. TIA everyone!
Denis
Old 11-14-2003, 12:06 PM
Harlan Chinn's Avatar
The window trim should have been set into the new seal with the glass and then roped or corded onto the window flange of the car. I'm not sure how to get it back in afterwards
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 11-14-2003, 12:51 PM
CHILI's Avatar
You can't. Has to go in before the window is re-installed. Sorry for the bad news, but sounds like you will need to remove the window. Think of it as practice!
"I understand that you want to drive fast, it's just that I want to go faster!" Move ova please
Chad aka "Chili"
1974 Base coupe in Carrera outfit.
No A/C, no Sun Roof, no power windows. Fast and light, just the way I like it. (Sad to say, it's sold. But at least it remains with us on this board.)
My car http://www.pelicanparts.com/gallery/CHILI
1969 RSR Project. Heavy on the word PROJECT! No pictures yet. Keeps breaking lenses of cameras.
Old 11-14-2003, 12:56 PM
canna change law physics
red-beard's Avatar
Pay someone else to do it. Not worth my time for the frustration.
Of course, I had it done in Tijuana....
James
Red-beard for President, 2020
Old 11-14-2003, 10:49 PM
Speder I need to do the same thing to my 82sc where did you get the seal I've been told many options and they have me confused as to which one to buy, xtra wide, or factory only, no aftermarket
Old 11-15-2003, 12:34 AM
Porsche Crest Rear windshield seal
The rear windshield seal has been superceeded by a newer design that does not have the defroster wire holes drilled and wires fed through. I have the two-stage defroster that has 4 wires running through the seal. I found that out when I ordered and received mine.
Try to keep the old seal intact to use to retrace the defroster wires into the new seal.
On the left is the old seal, on the right the new seal. I spliced my wiring connections for the defroster instead of pulling the mess from the back of the car.
Trace the defrost wires around to where they exit around the seal, set the glass back into the seal connecting each wire, install all of the metal trim around the perimeter before roping or cording the assembly back onto the car
Harlan Chinn
Old 11-15-2003, 09:10 AM
Team California
speeder's Avatar
I used a factory seal, purchased from Pelican Parts. FWIW, they seem to sell only OEM parts unless stated differently.
I cannot imagine using an aftermarket part in this instance, it is too important, (sealing against moisture/noise), and how much could you save? The factory one fits perfectly, it's made for the car.
Denis
Old 11-15-2003, 10:44 AM
