Unhappy cold start problem
1977 S would not start cold would take 5 or more times to start thae I had my warm up regulator rebuilt and it took care of the problem but now I am smoking like hell seems to be white smoke could this be a problem with the injection tune prior to this it ran well and did not smoke?
Old 11-14-2003, 05:13 PM
19 years and 17k posts...
azasadny's Avatar
Are you getting a good, fat spark on all of your plugs? Did you recently change plugs or wires?
Art Zasadny
Learning the bass guitar
www.ford.com
Old 11-14-2003, 07:23 PM
yes recently installed MSD box new plugs ,wires, backfire valve, valve job K&N filter ran great and then i sent off the warm up regulator for rebuild
1983 911SC
1977 911S "parting out"
Old 11-14-2003, 11:44 PM
azasadny's Avatar
You may want to double-check the spark plug gap and the integrity of the wires. Also check for vacuum leaks and fuel supply. Be sure the backfire valve is seated correctly.
I have to use the hand throttle when my car is cold and the hand throttle lever wasn't connected to the throttle, so it wasn't working. I replaced the lever and reconnected it to the throttle linkage next to the drivers seat, in the tunnel and all's well again!
Art Zasadny
www.ford.com
Old 11-15-2003, 05:11 PM
