 Where the H--- to get Wurth SKS Stone Guard????? Help
		I've read a bunch of info about undercoating and the product of choice seems to be "Wurth SKS Stone Guard". The preferred method of application seems to be using the "Gun" made just for the product. Screw the "Gun" on top of a container of "Wurth SKS Stone Guard" and shoot! All this sounds perfect for what I want to do except:
	Where in the heck does a rookie Pelican buy the stuff???? Thanks in advance for the help!!!  |
 Wow, I'm surprised Pelican doesn't offer this in their Online catalog. Give them a call @ 888-280-7799.
	Regarding the gun...this will work fine for $6.99: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=43761  |
 If Pelican doesn't have it then here is a reputable source:
	Scroll down to Wurth. http://www.carcareonline.com/bbm.aspx  |
 Yes, that HF gun will work nicely. But, make sure you have a way to regulate air pressure. The schultz will come out of the gun like gangbusters at a high pressure. You can hardly move the gun around fast enough. Schultz will run just like paint if you overdo it.
 Rick,
	I looked at PelicanParts' on-line catalog, and they show Wurth products as being under construction. I think what a lot of us would like to know is how do we get from a LOCAL supplier, not a mail-order house. I have looked at Wurth's WebSite, but they don't list local distributors. I have often driven past Wurth's main distribution center near the Orlando, Florida Airport, but short of calling them, there ought to be a listing of local distributors or retailers, but I don't think there is one.  |
 Andras,
	Wurth doesn't retail their products like others. Only thru commercial customers or a few specialty shops. Here in NJ there's the Wurth headquarters in Ramsey or Car Care Onlines storefront. Other than that there may be a couple of places but not many. You're best off contacting Wurth and asking them. I'd guess there are many areas with no local Wurth presence.  |
 Check at your local DuPont or PPG paint store. I this stuff on my restoration and it came out perfect. I used the Wurth spritzenpistol or what ever it is called to do the application. It is a very sophistcated spray gun that has adjustment for 1) fluid delivery  2)atomization  3)spray pattern  and 4) overall pressure. I needed all these to get it RIGHT. If you are using the cheapo harbor freight gun you might as well get some SEM or 3M in an aresol can and save some money and headache.
 AHHHHH! It is so simple guys!!!
	www.wurthusa.com click "customer support" then "customer service" Dial up any of the distribution centers located all over the US order with a Visa or MasterCard. Wurth Stoneguard SKS Gray Part # 0890031 (1000ml bottle) SKS Protective Gun Part # 08911061 1 bottle and 1 gun shipped was $90 when I bought it back in 2002. $20 bottle $56 for the gun, the rest was shipping... http://forums.pelicanparts.com/uploa...1069128542.jpg Hope this helps... BG  |
 Car Care Specialties
	Product Detail Product ID: 11338 Category: Undercoatings Wurth SKS Stone Guard Spray Gun Description: Low Pressure Spray Gun A low pressure "spatter" applicator gun for Wurth SKS. This is the easiest way to match the "pebble" finish of the factory applied undercoating. The guns screws directly to the SKS container and is trigger controlled. MSRP: $66.00 C.C.S. Price: $59.40 4 In Stock! Product ID: 11337 Category: Undercoatings Wurth SKS Stone Guard - Gray - 1000 ml Bottle Description: SKS is a water base, fast-drying and flexible undercoating that matches OEM Porsche, BMW, Mercedes, VW, Audi and other European automakers’ “body schutz” or undercoating. It protects the wheel wells, inside of body panels and the undercarriage against flying stones, chipping and corrosion. SKS doesn’t run on vertical surfaces, so it may be built up to desired thickness. It is resistant to oil, gasoline and UV, so it may be painted or left uncoated. It is best applied with a Wurth SKS Gun, but you may touch up small areas with a brush. MSRP: $28.00 C.C.S. Price: $25.20 42 In Stock! Check Volume Discounts  |
 That gun in the picture is NOT the one I used. I think the cost was about $300.
 I used the $60.00 gun in the picture. It worked great. Very little mess and it looks just like the factory did it.
 I have two Wurth guns and both are nearly identical to the one pictured above. Worked perfectly.
	Frankly I'd use the Harbor Freight one if I had to do again.  |
 Yea, I'd like to hear someone who has used the Harbor freight gun give us some commentary. Other guns will get the product on just as well I think, They may be a little or a lot more messy, I don't know.
	Zeke used a gun he got from an old sandblaster and it worked great from what i could see, but he said it was a mess. That gun above shot the stuff right where I wanted it to go with almost no waste or splatter.  |
 The gun from HF is designed to shoot 3M undercoat. I wouldn't compare it to an old sandblasting gun.
 Let's cut to the chase..................
	The original question was "where to get Wurth?" The answer is you can order it direct from the Wurth Distribution Center in Orlando or any of the opther Distribution Centers around the country; their prices are retail, yet cheaper than any paint store in West Palm Beach. But they will add sales tax, and shipping, whereas the paint store will add only sales tax to the higher price. Perhaps a wash in your neck of the woods. Hope this helps!!!!  |
 Andras,
	Are you implying that Craig is incapable of coming to that conclusion?  |
 Hey Rick
	Would you consider the Wurth to be comparable to the 3M as far as the gun is concerned? I guess if I can buy the 6.99 gun and it will do the same as the 60.00 gun, well then. I'd like to hear from someone who has actually used the HF gun to shoot Wurth SKS Stone Guard. BTW, thanks to all for the useful info. Certainly, my original question has been so very thoroughly answeered. Thank you all!!  |
 Craig,
	I'll do one better. I'll send you one of my Wurth guns and you can compare. The toughest part will be cleaning an extra gun and shipping back...I'll include shipping lables to make return easier. Oh yes...you can take pics and post your impression here as well.  |
 Also, if the HF gun stinks you have mine to do the job.
 lol
 The only difference between the Wurth gun and the Harbor Freight gun is that the Wurth gun (is expensive) screws onto a bottle of SKS and has a fancy coated handle whereas the Harbor Freight unit does not screw onto the SKS bottle and is plain aluminum.  You have to buy a separate plastic bottle, pour in the SKS and shoot.  I've used it, it works the same and the finish is the same assuming you know how to play with air pressure settings etc....   Having to buy the separate bottle is a pain but it was cheap (eastwood sells them). I choose to pay the $7 instead of teh $60 for the Wurth gun.  SKS cleans up with water so cleaning the bottle isn't a big deal compared with the 3M undercoat which is a solvent base and a fiasco to cleanup (not to mention that you can't paint over it).
	Now, having said that, please understand that Wurth also makes a different (more expensive) undercoat gun that includes features of a standard paint gun. It has controls for atomization and fan size. I believe this may be the unit originally mentioned at the start of this post. It's quite pricy and since most shops don't use them I just went with the cheap unit. SKS works fine for mid 70 and later cars but the earlier cars were undercoated with patroleum products that were completely different materials and are harder to reproduce texture wise. $.02 K-  |
| All times are GMT -8. The time now is 04:46 PM. |
