Craig Roche's Avatar
Porsche Crest Where the H--- to get Wurth SKS Stone Guard????? Help
I've read a bunch of info about undercoating and the product of choice seems to be "Wurth SKS Stone Guard". The preferred method of application seems to be using the "Gun" made just for the product. Screw the "Gun" on top of a container of "Wurth SKS Stone Guard" and shoot! All this sounds perfect for what I want to do except:
Where in the heck does a rookie Pelican buy the stuff????
Thanks in advance for the help!!!
Craig
1984 911 Targa
Old 11-17-2003, 08:35 AM
Wow, I'm surprised Pelican doesn't offer this in their Online catalog. Give them a call @ 888-280-7799.
Regarding the gun...this will work fine for $6.99: http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=43761
Warren & Ron, may you rest in Peace.
Old 11-17-2003, 08:39 AM
If Pelican doesn't have it then here is a reputable source:
Scroll down to Wurth.
http://www.carcareonline.com/bbm.aspx
Old 11-17-2003, 08:46 AM
Zeke's Avatar
Yes, that HF gun will work nicely. But, make sure you have a way to regulate air pressure. The schultz will come out of the gun like gangbusters at a high pressure. You can hardly move the gun around fast enough. Schultz will run just like paint if you overdo it.
Old 11-17-2003, 08:53 AM
Rick,
I looked at PelicanParts' on-line catalog, and they show Wurth products as being under construction.
I think what a lot of us would like to know is how do we get from a LOCAL supplier, not a mail-order house. I have looked at Wurth's WebSite, but they don't list local distributors.
I have often driven past Wurth's main distribution center near the Orlando, Florida Airport, but short of calling them, there ought to be a listing of local distributors or retailers, but I don't think there is one.
1983 911SC Chocolate Kiss (Smokey Quartz Metallic)
1991 VFR750F
1982 VF750S
Miata (wife's)
Audi A6 Quattro (family)
Old 11-17-2003, 09:16 AM
Andras,
Wurth doesn't retail their products like others. Only thru commercial customers or a few specialty shops. Here in NJ there's the Wurth headquarters in Ramsey or Car Care Onlines storefront. Other than that there may be a couple of places but not many.
You're best off contacting Wurth and asking them. I'd guess there are many areas with no local Wurth presence.
Old 11-17-2003, 09:45 AM
Check at your local DuPont or PPG paint store. I this stuff on my restoration and it came out perfect. I used the Wurth spritzenpistol or what ever it is called to do the application. It is a very sophistcated spray gun that has adjustment for 1) fluid delivery 2)atomization 3)spray pattern and 4) overall pressure. I needed all these to get it RIGHT. If you are using the cheapo harbor freight gun you might as well get some SEM or 3M in an aresol can and save some money and headache.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 11-17-2003, 06:01 PM
Certified Pre-Owned
BGCarrera32's Avatar
AHHHHH! It is so simple guys!!!
www.wurthusa.com
click "customer support" then "customer service"
Dial up any of the distribution centers located all over the US order with a Visa or MasterCard.
Wurth Stoneguard SKS Gray Part # 0890031 (1000ml bottle)
SKS Protective Gun Part # 08911061
1 bottle and 1 gun shipped was $90 when I bought it back in 2002. $20 bottle $56 for the gun, the rest was shipping...
Hope this helps...
BG
'84 Carrera Coupe
Old 11-17-2003, 08:10 PM
Car Care Specialties
Product Detail
Product ID: 11338 Category: Undercoatings
Wurth SKS Stone Guard Spray Gun
Description: Low Pressure Spray Gun
A low pressure "spatter" applicator gun for Wurth SKS. This is the easiest way to match the "pebble" finish of the factory applied undercoating. The guns screws directly to the SKS container and is trigger controlled.
MSRP: $66.00
C.C.S. Price: $59.40
4 In Stock!
Product ID: 11337 Category: Undercoatings
Wurth SKS Stone Guard - Gray - 1000 ml Bottle
Description:
SKS is a water base, fast-drying and flexible undercoating that matches OEM Porsche, BMW, Mercedes, VW, Audi and other European automakers’ “body schutz” or undercoating. It protects the wheel wells, inside of body panels and the undercarriage against flying stones, chipping and corrosion. SKS doesn’t run on vertical surfaces, so it may be built up to desired thickness. It is resistant to oil, gasoline and UV, so it may be painted or left uncoated. It is best applied with a Wurth SKS Gun, but you may touch up small areas with a brush.
MSRP: $28.00
C.C.S. Price: $25.20
42 In Stock!
Check Volume Discounts
1979 911 SC Targa
http://www.pelicanparts.com/gallery/Mike_Kast
Old 11-17-2003, 08:57 PM
That gun in the picture is NOT the one I used. I think the cost was about $300.
87 Carerra Coupe
04 GMC Yukon
07 Mazda 3
00 GMC Sierra
Old 11-18-2003, 04:56 AM
I used the $60.00 gun in the picture. It worked great. Very little mess and it looks just like the factory did it.
1979 911 SC Targa
Old 11-18-2003, 07:34 PM
I have two Wurth guns and both are nearly identical to the one pictured above. Worked perfectly.
Frankly I'd use the Harbor Freight one if I had to do again.
Old 11-19-2003, 06:17 AM
Yea, I'd like to hear someone who has used the Harbor freight gun give us some commentary. Other guns will get the product on just as well I think, They may be a little or a lot more messy, I don't know.
Zeke used a gun he got from an old sandblaster and it worked great from what i could see, but he said it was a mess.
That gun above shot the stuff right where I wanted it to go with almost no waste or splatter.
1979 911 SC Targa
Old 11-19-2003, 02:54 PM
The gun from HF is designed to shoot 3M undercoat. I wouldn't compare it to an old sandblasting gun.
Old 11-20-2003, 09:09 AM
Let's cut to the chase..................
The original question was "where to get Wurth?"
The answer is you can order it direct from the Wurth Distribution Center in Orlando or any of the opther Distribution Centers around the country; their prices are retail, yet cheaper than any paint store in West Palm Beach. But they will add sales tax, and shipping, whereas the paint store will add only sales tax to the higher price. Perhaps a wash in your neck of the woods.
Hope this helps!!!!
1991 VFR750F
1982 VF750S
Miata (wife's)
Old 11-20-2003, 09:44 AM
Andras,
Are you implying that Craig is incapable of coming to that conclusion?
Old 11-20-2003, 09:55 AM
Hey Rick
Would you consider the Wurth to be comparable to the 3M as far as the gun is concerned? I guess if I can buy the 6.99 gun and it will do the same as the 60.00 gun, well then. I'd like to hear from someone who has actually used the HF gun to shoot Wurth SKS Stone Guard.
BTW, thanks to all for the useful info. Certainly, my original question has been so very thoroughly answeered. Thank you all!!
Craig
1984 911 Targa
Old 11-20-2003, 10:05 AM
Craig,
I'll do one better. I'll send you one of my Wurth guns and you can compare. The toughest part will be cleaning an extra gun and shipping back...I'll include shipping lables to make return easier. Oh yes...you can take pics and post your impression here as well.
Old 11-20-2003, 10:15 AM
Also, if the HF gun stinks you have mine to do the job.
Old 11-20-2003, 10:17 AM
lol
1979 911 SC Targa
Old 11-20-2003, 03:45 PM
