Bruce Huling's Avatar
Send a message via AIM to Bruce Huling
Help! No heat! Family Jewels at risk !
I have been trying to get my heat to work on my 1976 911s and no go. I set the top lever to the far right, the middle lever to the far right, the bottom lever to the far right, and pull up both floor mounted levers all the way. The fan motor activated by the dash controls is working, and the fan motor activated by the floor mounted levers is running. The floor mounted levers when in the full up position also close those two respective vents underneath the car that I assume alow the shrowd fan o push air from the intake down thru the exchanger and down the tunnel to the front of the car. Any suggestions besides a coat?
bh
Gruppe B #367
1976 911s with 79 euro 3L
1995 Ford Powerstroke F250
1973 CZ400
1980 Maico 440
"If it aint broke, dont fix it"
Old 11-17-2003, 07:41 AM
Irrationally exuberant
ChrisBennet's Avatar
Get under the car and make sure the heater boxes are working. Follow the heater hoses up from the heat exchangers, on either side of the transmission.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-17-2003, 07:44 AM
na2ub's Avatar
I think your controls are quite similar if not the same as mine. The top two dash levers are for fresh (cold in the winter) air. With the top lever to the right, you have wide open fresh air blowing in. This may be part of your problem. With the top lever to the left you should be able to feel heat from the defroster (bottom lever right) or the floor (bottom lever left.)
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 11-17-2003, 07:46 AM
Eric Mckenna's Avatar
Real 911 owners don't need NO heat.. ( cuz it adds weight )
I live in Ohio and it's already cold here and I have NO heat.. Mongo NO NEED HEAT...
drive with the windows down to keep the windows fron fogging up. I do .
or just don't breath! hahaha I have tried it and it doesn't work . well it does... but only until I have to take a few breathes.. hahahah!!!
good luck!
Eric
Famous last words..
"Hold my beer and watch this...'
" The reason the Irish are always fightin one another is that there are no other worthy opponents ".
Old 11-17-2003, 08:52 AM
Team California
speeder's Avatar
Bruce, Reading the owner's manual section on heat controls would go a long way towards solving your problem, if still no heat when you actually turn it on, get back to us.
Denis
Old 11-17-2003, 10:28 AM
Senior Member
Superman's Avatar
Top lever to the left. Middle lever, doesn't matter as long as the top lever is to the left. Bottom (red) lever, to the left. Two levers between the seats, fully up. This should work.
If you need to defog the windscreen, put the middle lever to the right and the top lever about in the middle position.
Mocha 1978 911SC. "Coco"
Old 11-17-2003, 11:12 AM
As far as reading the owners manual, been there, did that-no luck. My manual says to place the 3 dash controls to the right (sounds wrong). As far as reading the instructions written on the controls-been there did that, no luck (says place dash controls to the right) . Between Superman and Na2ub, THANKS for taking the time to answer this. Yes, amazing at it sounds, I have not had to use my heat before (Arizona). Usually, it is plenty warm in the car unles it is snowing, so I have had little need for the heat controls up until recently (started going up north for fun). Thanks again.
bh
Gruppe B #367
1973 CZ400
1980 Maico 440
Old 11-17-2003, 02:11 PM
disband
juanbenae's Avatar
cool temps are actually good for the jewels. buddy of mine haslow swimmer count and his wife wants a baby bad. she has him in a bath tub with ice water a couple times a week.
go figure?
Old 11-17-2003, 02:35 PM
rickeolis's Avatar
Porsche Crest
Your heat control boxes are not opening.
The red lever in between the seats opens these, but if you get no heat with it pulled up they are not working for some reason.
Get under the car (safely secured) and see why they are not opening, if something is broken, you can remove the return springs in them and use a piece of wire to hold them in the open position until you get them fixed right.
-Rickeolis-
1986 Corvette
Old 11-17-2003, 02:41 PM
Hilbilly Deluxe
emcon5's Avatar
82 911SC Coupe
GTI Cup #43
Old 11-17-2003, 02:44 PM
Send a message via ICQ to Kurt B Send a message via Yahoo to Kurt B
Do those cars have footwell blowers? I hooked my footwell blowers up to a separate switch (they were part of the climate control system,now gone).
If not, you need to check the trunk to make sure when you pull the tabs, the cables move and properly open and close the flaps in the front ducts. The front blower only blows cold air. It would be nice if the front blower blew whatever air you opted for, but it's one of those confusing things you just have to deal with.
Certainly, you can take off the kickpanels in the passenger compartment on either side of the front seats and pop off the ducting and see if heat is getting up to the front cabin area at all. It should be very toasty once those kick panels and ducting is off.
My engine bay blower doesn't even work right now, yet I get enough heat to drive me out of the car w/ the footwell blowers, but I don't know when they (front blowers) were first introduced.
Get the car hot, get the engine fan working, then start working your way forward to find out where the heat is ending.
it's either, the flaps on the heat exchanges are stuck closed, or the cables that pull the flaps in the trunk ducting are not working, and those are closed (but it should always direct it somewhere). In any case, once you get those kickpanels off if heat is not coming into the cabin from there, flaps on the exchangers aren't working or there is a break in the ducting back there letting the hot air escape.
-kb-
Old 11-17-2003, 02:55 PM
Jim Smolka's Avatar
If the heater boxes are in bad shape, it maybe time to rebuild or replace them. When removing the 6mm nuts that secure the boxes to the car, do not break the studs. If necessary, use the fire wrench to loosen the nuts. This is best done with the motor & tranny out of the car.
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 11-17-2003, 05:26 PM
Autobahn Garage
Eric I live in Ohio to,got a 911 with no heat. But it's got headers, and Webers and it's fast oh my. Hey were in Ohio do you live?
T Tanner
76, 911s w/ Webers
76, 914/4
57, Speedster
Old 11-17-2003, 05:53 PM
