-   -   Front end squeeks. (http://forums.pelicanparts.com/porsche-911-technical-forum/136223-front-end-squeeks.html)
K. Roman 11-18-2003 02:20 AM
Front end squeeks.
Does anyone know how to stop one of the many squeeks I have in my Targa?
I don't recall it ever being so annoying.
It sounds like it's coming from the drivers side.
Shocks?
Very novice, but thought I could count on the board.
Don't wanna take it to shop.
Would love to fix it myself.
Thank you and have a great week!
SmileWavy
Shuie 11-18-2003 02:26 AM
Have you replaced the suspension bushings recently?
K. Roman 11-18-2003 02:29 AM
No, I purchased the car in May, had a PPI done but I don't think they checked that.
Shuie 11-18-2003 02:34 AM
It could be poly front bushings that are squeaking.
Check this out:
http://forums.pelicanparts.com/showthread.php?s=&threadid=65537&highlight=poly+bu shings
K. Roman 11-18-2003 02:42 AM
Wow. Heavy stuff. The problem is I don't have a proper shop like that to work with.
I do have some grease though. Maybe I could get away with just lubing it for a while.
thanks for the thread/link!
K. Roman 11-18-2003 02:56 AM
By the way, is your icon from the Misfits?
If it is, thats very cool.
Shuie 11-18-2003 03:20 AM
Yes, its the Misfits logo.
Use Silicon-based grease on the Neatrix and any rubber-type bushings. You can use regular grease on the poly and plastic type bushings.
When I bought my front bushings, I didnt have the tools or the patience to do what Chuck did in that thread. I bought a set of his poly-bronze bushings instead. They are not cheap, but I think they are worth it. The installation is a breeze and they are quality parts.
Im not an expert though, so dont grease anything until you are sure its the bushings. :)
Good luck.
dsfnctn 11-18-2003 10:32 AM
squeeking front suspension
My car had a loud squeek in the front end. It is a track set up RS Replica. I was going to live with the squeek then I got under the car and disconnected the sway bar and the squeek went away. I dissembled the bushings and lubbed them and the squeek dissapered.
