-   -   why disconnect the O2 sensor? (http://forums.pelicanparts.com/porsche-911-technical-forum/137062-why-disconnect-o2-sensor.html)
Thack 10-07-2004 07:35 AM
It'say too lean if it stumbles and dies. When it's way too rich the idle will surge and hunt up and down. The 911SC has a deceleration valve to help keep the RPMs up after you lift off the gas pedal. It is designed to keep you in the right RPM range while shifting. Look into to this feature on your car and see if you can richen up your mixture. If you hook up your O2 sensor while warm and your idle picks up then it needs more fuel.
mike
MotoSook 10-07-2004 08:04 AM
Alex, you have a DME engine ('86 Carrera)...there has been a lot of discussion on the driveability of the 3.2 engine. Disconnecting the O2 sensor on the DME is not going to fix much... my guess...search "speed sensor" (flywheel speed).
Don't confuse the disconnection of the O2 sensor on a CIS engine with disconnection of the O2 sensor on a DME engine.
Noel 10-07-2004 07:16 PM
mike
Actually, the deceleration valve is designed to prevent an overly rish condition when you come off of the accelerator suddenly at high RPM. This exibits itself in the form of the RPMs hanging for a second or two after you release the throttle. Many disable this valve by disconnecting the vacuum hose and plugging it with a screw. This makes your RPMs fall more quickly between shift.
indigowhale 10-08-2004 11:34 AM
Started my car this morning after I thought I fixed the air leaks and it bounced from 500 to 1500 back and forth for about a minute.
At lunch I decided to mess with the CO mixture ath the AFM and got the car to perform much better. I don't have a CO analyzer, I just winged it at experience the surging when it was too rich and the slight puffing when it was too lean and stopped in the middle somewhere.
I am going to see someone who has an analyzer, but can you adjust the mixture at the tailpipe if you have a Cat? I don't think the folks I will visit have the port probe before the cat.
Can someone she some light on adjusting the CO in a DIY friendly way? I have the Bently but it almost refers you to the dealer.
Paulporsche 10-08-2004 12:18 PM
Indigowhale,
You are doing what I have always done. With my car, if I keep the mixture a little shy of when the revs start to bounce when you come to a stop, or when the idle hunts when warm, then the mix seems right. I find I have to adjust this somewhat seasonally.
Alternatively, some use a Gunson Gastester or have a shop w/ an analyzer do it. JW recommends 3.5% CO.
There are also threads about raising and lowering the sensor plate by hand and seeing how the revs change to determine the correct CO.
VaSteve 10-08-2004 12:38 PM
You are supposed to take the plug out of the cat. Attached is a photo. Mine is soaking in PB blaster b/c it's in there pretty good. I plan on doing this tommorow and I don't want to fight it while it's warm. :cool:
Read also this thread towards the bottom. I'm going to try Charlie's method as well.
http://forums.pelicanparts.com/porsche-911-technical-forum/181669-afr-meter-gunson.html
indigowhale 10-08-2004 05:05 PM
Thanks VASteve, the picture did not attach.
So I went by two service stations asking for a gas analysis and they looked at me as if I was crazy. Here in the very controlled state of VA, emissions is a bid deal and the machines are always in demmand--DIYers not welcomed.
I am back to the manual method until I find a gas analyzer. The car was running so well after the AFM adjustment that I burned some rubber coming out of the station and hit close to 7K RPM with a hole lot of ease. Not a single complaint from the car and no hesitation or fuel cut-off. However there is some slight surging when driving easy so I suspect the manual adjustment is still way off, but what a difference that silly screw makes.
VASteve are you in the northern area? What are you using to gauge your CO%?
Lorenfb 10-08-2004 09:30 PM
Check out this web site ( www.systemsc.com ) on the Diagnostics page and the
section on Poor Running. The AFM must be adjusted internally to properly
affect the CO value over the full RPM range versus just the screw for an idle
CO setting.
indigowhale 10-09-2004 08:21 PM
Looked at that link, but not sure about opening up the AFM again. It was not easy.
I finally lost the allen wrench after several magnet recoveries in the engine's black hole trying to adkust mixture, so I can't mess with it anymore.
Does anyone make a tool for this? and is there a tailpipe analyzer that is reasonably priced for the DIY? If I can't do it myself it is going to the wrech.
My wobbly idle still persists, instead of being a purring kitten is a galloping horse. I've turned screws in every direction along with several others on this board to no avail. Even put in a new HTS today.
Any help welcomed. Indigowhale:confused:
stlrj 10-10-2004 07:58 AM
The "galloping horse" idle can be corrected by reducing the amount of bypass air on the throttle valve in order to reduce the base idle speed.
Joe
SpeedracerIndy 10-10-2004 11:37 AM
Originally posted by stlrj
Yeh... and all the bulletproof air cooled 911's run 02 sensors with the 78/79 SCs as the only exceptions...how do you explain that?
Joe
None of the ROW SCs used oxygen sensors. It was an add on to meet US emissions regulations.
