optima install w/ battery cut-off switch
a couple of pics. showing my optima install. i mounted the battery to a small sheet of aluminum, then mounted the aluminum to the factory battery location. i used pelican's battery cut-off switch to lengthen the factory ground strap rather than replace it with a longer strap. the cut-off switch is a welcome addition, easy to cut power to the car for wrenching, security, and storage.
![]() sorry for the blurry pic.
Tim '06 Cayman S '96 993tt '87 930 (gone, but not forgotten) |
Put a protective cover over the positive terminal......
Otherwise....looks good ! Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Designer King
Nice. How much weight do you figure you save over the stock battery ( which I think is +/- 48 lb)?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
thanks Wil, think i'll use a marine grade post cover.
Paul, i believe the optima weighs approx. 37 lbs.
I've had the same cutoff switch on my Interstate for years. Love it.
The ability to remove the knob connector is great for security.
Warren & Ron, may you rest in Peace. |
Re: optima install w/ battery cut-off switch
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
For added convenience when/if you remove the green knob for security, you can add an inline fuse (red wires in pic) between the cutout switch and the ground terminal. That way, the accessories will continue to operate (clock, alarm, radio presets, etc.), but if someone wants to crank the engine (as in hot wire), the fuse will blow and prevent that from happening (at lease until they figure that out).
BTW, I weighed this in at approx. 35 lbs. Sherwood |
Looks great.
I have used the cutoff switch in my 208K mile Volvo. It works great, but every blue moon, the knob will need to be cycled (loosened and tightened) to get to start the engine. Once every 3 - 4 months I have found.
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Steve, it's 1/8" aluminum. it's the same size as the AJ USA mounting plate.
"...But if one is chasing a slow current draw this wont help..."
Actually the inline fuse holder is a convenient location to test for parasitic current draw. Unscrew knob, remove fuse, clip ammeter leads onto the fuse prongs, read ammeter. Sherwood |
Sherwood, that's a great idea. are you using a fuse > 5A?
Tom,
5A should be fine. I had a 10A fuse handy and use that (overkill). Sherwood |
