-   -   Why can't I search "SC" (http://forums.pelicanparts.com/porsche-911-technical-forum/137462-why-cant-i-search-sc.html)
Bravo 11-27-2003 04:35 PM
When I try to do searches and put in SC it says word too short 3 letters min. What do I do?? Just bought an SC and looking for info! Thanks in advance
Dean
Glasgow 911SC 11-27-2003 04:42 PM
Be more specific I guess. like 'cis' for injection system etc. Anything in particular you are looking for?
Bravo 11-27-2003 04:46 PM
No, not really just general info. I bought a 79 Targa from a fellow Pelican member today in Portland OR I am from WA and sitting here at my relatives just itching to get started on her!! Ya know! upgrades and such.
jmohn 11-27-2003 05:18 PM
First, take a deep breath, then think about it. If you could search for just "SC" you would get, literally, hundreds of pages of "hits". You still wouldn't know where to begin reading. Try to narrow your search to something more specific, suspension, CIS, electrical system, valve timing, interior, wheels, tires, etc. Good luck with the "upgrades".
Jerry M
'78 SC
Bravo 11-27-2003 05:26 PM
Thanks jmohn -- I see what you mean --- dig deeper, more specific ah yes
jmohn 11-27-2003 06:02 PM
Dean,
If you're looking for general info on the SC models, you should read the SC FAQ on Rennlist. Located here. It will give a good over-view of the SC's and some popular modifications and upgrades.
Jerry M
'78 SC
Bravo 11-27-2003 06:36 PM
Thanks for the link I read the whole thing. I learned some stuff thanks!
stomachmonkey 11-27-2003 06:37 PM
I have also found the limitation a bit annoying.
I am contemplating buying a C4.
I know there are a few issues with the car and want to do a little research on them.
I can't do a search on "heads AND C4" because C4 is not considered a word.
If I search on "heads" only I would need to weed through posts on other models.
I know I can use 964, but then I may miss posts where the car is referred to only as a C4.
oh well, life is not perfect.
I'm sure the developers of the BBS software put the limitation in for a good reason.
Regards,
Scott
Bravo 11-27-2003 07:20 PM
My point exactly because even if I search CIS it give all of the cis threads not just the sc ones. I thought maybe you could use a wildcard but I dont know how
Moses 11-27-2003 07:56 PM
You are unable to do a search for "SC" because you do not have proper security clearance.
Start with a search for "SCWDP". Now your on the right track. ;)
moazam 11-27-2003 08:09 PM
Soooo..I figured out a way to do the search for just "SC"....but I can't tell you! :)
Seriously. I figured it out, but the results are huge and these kinda searches will seriously tax the DB. If Wayne is OK with it, I would tell ya how..but I figure he put a minimum 3 letter search limit for a good reason.
stomachmonkey 11-27-2003 08:24 PM
Just figured it out also.
Got like 29115 posts for just "cs".
Tried it with "C4 AND heads" and only got 24 results.
So if a 2 letter is used with another qualifier it may not be so bad.
Scott
Bravo 11-28-2003 08:24 AM
Thanks Moses, Now that I finally got rid of that long nose and into the best 911 years I need to find my scwdp badges, stickers, etc. I did a search for scwdp and got lots of info.
Joe Bob 11-28-2003 09:37 AM
The software won't let you search on a word less than 3 letters. SC or RS gets the error message. Try 911SC.
Bravo 11-28-2003 11:37 AM
Will do!
dickster 11-28-2003 01:28 PM
thats funny, i tried the search for "sc" earlier :D
greenmonster 11-28-2003 05:39 PM
You can also wildcard SC as "SC*". It'll bring up all records with words that begin with Sc, but if you limit the search to thread titles, it works for the most part.
back to lurking...
Wayne 962 03-03-2009 11:00 PM
I just tried enabling two-character searching. I need to rebuild the indexes and then see if this takes down the server...
-Wayne
RideShoot&Drink 03-03-2009 11:49 PM
-Wayne
ah...that's what killed my search and disabled "Search" function...
bonkers 03-03-2009 11:53 PM
Mwuhahahahahaaaaaa! Yet more confirmation of the clear superiority of the Carrera over the 'Sorta Carrera'.
:D
Wayne 962 03-04-2009 12:54 AM
It works - pretty well. I meant to switch this over and try it when we went to a dedicated search server last year, but completely forgot about it, until I tried to search for CIS tonight, and realized that the server was set to only index 4 characters and greater.
This should be a big improvement.
-Wayne
karlusmagnus 03-04-2009 06:12 AM
-Wayne
I thought that it was 4 characters or greater. When I typed "MFI" or something similar, it did not work, so I improvised with things such as "MFI Higgins" :D or something like that.
Ricks911s 03-04-2009 01:30 PM
No offense intended to the search method embedded in the forum. But I much prefer using this method:
(1) http://www.google.com/advanced_search?hl=en
(2) input your search terms in related fields
(3) in last field: "Search within a site or domain:" put "pelicanparts.com"
I use to have problems with 2 characters and numerical numbers. So I just used this work around, and I found it's yielded better results sometimes than when I do pelican.
I will say though, that pelicanparts forum title searches confined to a specific forum (for me 911 Technical and/or Rebuilding) are my favorite quick/easy way to search.
Okay, now I just wasted another 3 minutes of my day. Hope it was of some use to someone.
Por_sha911 03-04-2009 03:49 PM
You can use the other term for SC: POS
Mwuhahahahahaaaaaa!
Canada Kev 03-04-2009 07:02 PM
I suppose this should be an added incentive for people starting a thread to sorta describe the topic in the title. Makes it easier than searching for something located in "Oops, I pulled a boner" or something similar.
70SWT 03-04-2009 07:54 PM
You can also attach an asterisk to a short search term (example: *SC) at this and other forums to force a search. Sometimes it works, sometimes it doesn't.
enzo1 03-04-2009 07:57 PM
rick911s, that works great in this application and more ,thanks
