headlights not working
Where do I start to look for the problem of headlights not working? Parking lights work, blinkers oK, taillights work. The high beams flash on sometimes with the stalk sometime not. No low or high beams with the switch. 1988 Carerra
Old 12-02-2003, 10:01 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
the switch on the column, then the switch on the dash.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 12-02-2003, 11:27 PM
Replace the stalk switch
Had the same issue, asked the same question, got multiple replies to replace the stalk switch - apparently a common weak spot.
Got new switch (from Pelican, of course), changed out, problem disappeared. Opened up old switch - high beam contacts almost melted.
So....replace the stalk switch! Not a big job.
Old 12-02-2003, 11:28 PM
