carlos's Avatar
Front Brake Lock Up
Hello,
I have an 86 930, and just rebuilt the front brakes with new rotors and pagid brake pads. The front brakes are locking up before the back ones, and it's bad if it's wet out. Back brakes are ok. Is there a proportioning valve or could I have done something wrong? The car has 44K miles on it and is perfect otherwise. Thanks!
Fastlos
86 930 PowerHaus Stage 1 w/sc cams scary fast
68 AMX 390 burnout king
97 GMC Z-71 4WD 4/door gas guzzler for sale
86 930 Powerhaus Stage 1 W/SC Cams Billstein Sports Weltmeister Torsion Bars & Strut tower brace Kinesis 9 & 11 K-28's Lowered Balanced "Scary Fast"
87 BMW 735I "Kid & Grocery Hauler"
*68 AMX 390 Go Pack
4-Speed "Burnout King"
*82 Honda Trail 70 "Just Fun"
*Future Cart Champion Son, Mateo "Go Da Da Posha Go Trbo"
Old 12-01-2003, 11:03 PM
Do you have different pads on the rear? If so, that might be it
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 12-02-2003, 04:57 AM
Send a message via ICQ to old_skul
That's what's supposed to happen. It keeps you from spinning every time you threshold brake. The rears are braking, just not as much as the fronts. And that's okay, since most of your braking power *should* come from the front.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 12-02-2003, 08:21 AM
Bill Verburg's Avatar
First be sure that the rears are working correctly. The fact that you rebuilt the fronts suggests that the backs may need similar attention. Pads need to be the same f/r unless you are correcting some previously existing condition. The rubber brake lines will eventually swell internally causing issues similar to those you have described.
Yes, there is a p/v on an '86 930, it is a 55/46 version and is not very intrusive in action(though earlier 930s worked fine w/o any p/v at all), there is little that can go wrong w/ it.
Bill Verburg
Old 12-02-2003, 01:04 PM
carlos's Avatar
Thanks so much guys, I will check all these things out this weekend.
Carlos
*68 AMX 390 Go Pack
Old 12-02-2003, 02:15 PM
