DavidI's Avatar
Cool Just installed a popoff valve
I just purchased a popoff valve from Pelican and installed it in my 83SC. The directions were clear and simple to follow. Total time was about 30 minutes.
As a side note, I purchased a right angle adapter for my drill from Harbor Freight for about $10. With this attached, the job was pretty easy.
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 12-06-2003, 05:57 PM
Unregistered
sammyg2's Avatar
Way to go Dave. I assume you did the install with the air box in the car?
Old 12-06-2003, 06:35 PM
Good stuff. Wish I did that before my airbox blew Would have saved an engine drop.
Old 12-06-2003, 06:42 PM
DavidI's Avatar
I did install the popoff valve with the airbox in the car. It went well. I took your advice and headed out to Harbor Freight today. Thanks again Sam, David
99 996 C4
11 Panamera 4S
67 912 (sold)
Old 12-06-2003, 07:17 PM
Binge User
Schrup's Avatar
I just did mine last month. I hate to read the directions, set the arbor too deep & almost drilled a hole in my WUR chamber, I still need to apply some epoxy to each side of the hinge pin to keep it from sliding out. I'm not sure if any of that was in the instructions, but perhaps I should start to read them. Naw.
Paul
Old 12-06-2003, 07:32 PM
