-   -   alignment setting for lowered car (http://forums.pelicanparts.com/porsche-911-technical-forum/138965-alignment-setting-lowered-car.html)
yeuporsch 12-09-2003 11:07 AM
Does anyone has a setting for a lowered car? Mine is lowered to 24 at the rear and 24.75 in front.
Just redid my front a arm bushing, turbo tie rod ends, new ball joints. Now I'm getting it aligned. The alignment tech said he can align it to any setting I want.
I remember someone posted a setting that is for street use.
Thanks in advance.
John
Chuck Moreland 12-09-2003 11:17 AM
For street use, you can use the factory specs. However, you may have problems dialing in the camber lowered that much. If you can get both sides 1 - 1.25 degree negative, that would be a good street/performance compromise without eating tires much.
JTO 12-09-2003 11:38 AM
Chuck,
What about toe? My car ran out of adjustment and they couldn't get zero in the front.
Troy
stlrj 12-09-2003 11:43 AM
Forget factory specs, they can only be done at factory height. Below that, you do what you can to minimize excessive negative camber.
Or if that's what you're looking for, there you have it.
Joe
RANDY P 12-09-2003 02:54 PM
check the top post under my name:
http://forums.pelicanparts.com/showthread.php?s=&threadid=116704&perpage=20&highl ight=alignment&pagenumber=2
stlrj 12-09-2003 05:52 PM
"As long as it isn't factory," is what he forgot to mention.
Joe
