Dept store Quartermaster
The stroke vs bore thread
What is considered the better route to displacement increases? I would assume you would want a short stroke motor for quicker revs and lower piston speeds but I could be wrong
Also, would not a short stroke motor have inherently better balancing as well? I realize that torque is improved with long stroke motors but how much?
Cornpoppin' Pony Soldier |
Stressed Member
Len-
It is a misconception that long stroke motors produce more torque than short stroke motors. This misconception is based on the fact that long stroke motors are often tuned to produce increased torque as a route to horsepower because the alternative (higher RPMs) isn't possible due to unacceptably high piston speeds. In order to realize the potential for the theoretical increase of power possible with a short stroke engine, the potential for higher rev capacity must be realized. This means that the valve train must be capable of such RPMs, and that the induction track will have the capacity to move air into the engine while not forcing the air to move at unreasonable speeds. So, for a Porsche engine, the long and the sort of it is (ha ha), either approach is fine. Porsche has never really made a "long stroke" engine anyway, just short and shorter. It's relative. Other factors seem to be of more consequence (availability of pistons and cylinders, camshafts, etc). Me? I'm building a short stroke because I like the IDEA of it, and it was a good way to go given the parts that I started with. -Scott
'70 911E short stroke 2.5 MFI. Sold ![]() ![]() ![]() '56 Cliff May Prefab |
A longer stroke motor will produce more torque absolutely with a few qualifications. The indicated mean effective pressure in the cylinder over the time span of one half cycle must average to the same value as the smaller stroke motor. If this is true the engine must produce more torque. The lever arm of the crankshaft is longer.
Just changing the stroke of the engine will not ensure this result. There are so many open variables in an engine that a major change like stroke must be made with many other changes. Possible intake/exhaust runner length, camshaft, and valve changes just to name a few. This would take a pretty hefty R&D budget. Stroke vs. bore changes seem to be like turbo vs supercharge, a personal ideology. Don't even get into the long vs short rod debate. Matt |
The big benefit of a "long stroke/small bore" engine is that it is easier to optimise the combustion chamber shape while maintaining a high CR. One of the biggest challenges for F1 designers working with VERY short stroke (40mm's) - BIG bore engines (94-100 mm's) is that the combustion chamber gets wider and wider and flatter and flatter because of the big bore and the big valves needed to pull all of the air needed at 19000 RPM. It gets real tough to have clearence for valve overlap at TDC without pockets in piston, which reduces the CR again. The 2.0S's had a similar problem.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
Flame travel speed is also a problem especially with large bores at high rpm's(combustion chamber shape plays into this). But spark ignited engines have an upper limit usually stated at 6". No consumer car engine is even close, but it is good to note that there is a limit.
I also have several books that state that frictional losses associated with side load changes is negligible. Larger bores also have have more surface area for frictional loss. These are all part of the qualifications statement from the previous reply. Off to the jet airliner Have a good weekend. |
Matt, you are overlooking a key point.
It is true the long stoke has more leverage, but the short stroke has more piston area. Hence the short stroke piston is exerting more force on it's shorter lever arm (assuming displacement is kept constant). The change is directly proportional, so all else being equal both engines will produce the same torque.
Chuck Moreland - elephantracing.com - vonnen.com |
the question i have for this thread is how much is it to bore out and up the displacement on my 3.0--->3.2?
Check with Bruce M. I remember him having a stroker turbo and being very pleased with the way it made some big HP/torque numbers.
autoxracer31, generally boring isn't done with these motors, usually the method of increasing bore is to buy new P&C which I believe runs around $3000, maybe more maybe less, I think the range could be $2k-$4.5K with 3K-3.5K being the norm.
Banned
The Rod ratio also needs to be factored in. Steve
I came across this on another BBS and figured I'd share it here since the question of stroke versus HP and torque comes around every few months. This would seem to be pretty close to the final word. Unfortuantely, like many things, it isn't so much the final word as a whole lot of words.
The following excerpts are from SAE TECHNICAL PAPER 980126- The Influence of Stroke-to-Bore Ratio and Combustion Chamber Design on Formula One Engines Performance, available from the SAE. "...within real life design constraints. The effects of the stroke-to-bore ratio on both the volumetric efficiency and the thermal conversion efficiency have been investigated. Flame front area maps, wall areas wetted by burned gases, mean flow field patterns and main turbulent parameters have been compared for two different S/B ratios. Since higher intake and exhaust valve areas per unit displaced volume result in a higher volume of piston bowls, a lower S/B ratio leads to a lower compression ratio, which strongly limits the indicated mean effective pressure. Therefore, in the second part of the paper, an analysis of the influence of the piston shape on combustion process has been performed in order to optimize the imep of the lower S/B ratio engine. The overall technical objective of racing engine design is the achievement of the highest possible power levels. A simple analysis can reveal the effects of the main engine parameters on the brake power Pb delivered by a fourstroke cycle reciprocating internal combustion engine For a given total displaced volume, high engine speed, high compression ratio, high volumetric efficiency and low stroke-to-bore ratio are required in order to obtain high levels of power. High rated engine speeds dictate a diminishing of the stroke due to mechanical stress and friction considerations. High volumetric efficiencies call for higher valve areas per unit displaced volume, resulting in a bore that increases with the rated engine speed. On the other hand, the diminishing of the S/B ratio determines a lower thermal conversion efficiency since it leads to a combustion chamber design far from the optimum one required for an efficient combustion process. In fact,as the S/B decreases, combustion duration increases, as well as cycle-by-cycle variability and chances of misfire or partial burning. Since performance improvements call for low stroke-to-bore ratios, a detailed study of in-cylinder processes is required in order to achieve a compromise between thermal conversion efficiency and volumetric efficiency. Since higher intake and exhaust valve areas per unit displaced volume resulted in higher volume of the piston bowls, the diminishing of the S/B ratio led to a lower compression ratio. Although this is often sufficient for avoiding knock, it strongly limits the imep. Therefore, in the second part of the paper, an analysis of the piston shape influence on combustion process has been performed in order to optimize the compression ratio of the lower S/B ratio engine. The objective of a combustion chamber is to produce fast, stable and repeatable combustion processes with a high thermal conversion efficiency. The objective of racing engines is to provide a high specific power by achieving a high thermal conversion and high volumetric efficiencies. For a fixed total displaced volume, high power density requires high rated engine speeds. Hence, to obtain high volumetric efficiencies at high engine speeds and to limit friction and component mechanical stress, low S/B ratios must be adopted. Due to the higher maximum speed and volumetric efficiency, for constant fuel conversion efficiency, the engine with higher bore to stroke ratio should have about a 5% gain on brake specific power. The poorer engine fuel conversion efficiency is expected to reduce this gain. A CFD analysis was carried out in order to gain more insight regarding the effects of S/B ratio changes on racing engine performance. Two different S/B ratio engines were compared: since the reduction of S/B ratio was performed within actual design constraints, the low S/B ratio engine presented a 3.2% lower compression ratio. The analysis of the influence of S/B ratio on volumetric efficiency and thermal conversion efficiency led to the following conclusions: • Decreasing the S/B ratio results in the improvement (up to 4%) of the volumetric efficiency in the range of medium to high engine speed, while it determines a reduction in the volumetric efficiency at low speeds. • The thermal conversion efficiency falls while S/B has decreased as a consequence of the much lower burning rate due to both the lower compression ratio and the lower fuel mass effectiveness. The reduction of imep is balanced by the increase in the maximum rated power rotational speed. However, as a result, the two different S/B ratio engines present the same indicated power. • In order to achieve the highest possible gain from a S/B reduction, an optimization of the combustion chamber, with particular emphasis on compression ratio, is required. • Calculations clearly show the important role played by compression ratio on engine performance. An increase of the compression ratio of 3.2% determines a power gain of about 2.9%. • Finally, computations reveal that a proper optimization of the piston shape could produce significant improvement in the combustion process quality."
You do not have permissi
I'm still waiting for the technology of oddly shaped I/E valves that together make a circle and each have a spark plug(multiple) imbedded in the center. No head space wasted and multiple ignition points to configure flame propigation.
Meanwhile other things are still happening. |
