I can't determine AFR from the NB02 sensor output, but I can clearly see that you are running very very rich. Not sure if this is the reason for the missing 80Hp though. Below is a plot of O2 voltage vs RPM for your WOT run. Anything above 0.5v is rich.
I'd say dial the VE back until you get about 0.8v across the WOT run. Your other option is the get a WB02 and gain better insight into the AFR. Also in the datalog you were still in "Warmup enrichement" mode. It was adding about 5-10% more fuel. I guess your engine wasn't fully warmed up. ![]()
Tony '78 911SC with BITZRACING EFI conversion kit |
Make sure you're getting an accurate/reasonable temp reading from your sensor. Should be pretty close to ambient temp before you start it up. Doesn't have to be accurate, but close would be good. If the sensor connections aren't done correctly, the Megasquirt will think its very cold. Don't ask me how I know.
-Mac |
It's tough to get an O2 sensor much above 1V, so something looks a bit funny with the data...
Matt B '73 911E |
The CIS Nightmare Is Over!!! The car starts, as it should!! I’m running EFI on my 1981 911 SC, now I know what a 911 SC should feel like!!!
This was a Complete Satisfaction, No Regrets! kit from BITZ Racing! If you want the best CIS to EFI conversion kit then this is the one to buy, the installation was a breeze, the tech support was unsurpassed, the installation guide was marvelous!!! I kept the original Porsche CIS look in the engine compartment, and it was a very easy install without any glitches. The throttle response is exhilarating, the power is very pronounced, no comparison to the CIS sluggish response. The engine actually starts without any issues, hot or cold, as it should! I’ve been driving it straight for couple of weeks and it runs great!!! I will not hesitate to recommend this kit to anyone, ABSOLUTELY NO DISAPPOINTMENTS HERE!!! Thanks Again Tony! ![]() ![]()
Mike 2002 996 911 Carrera Cab 1998 Boxster S 2002 BMW X5 1978 FJ40 Land Cruiser 2005 Jeep Liberty CRD - Diesel www.europautoparts.com Last edited by Europa Auto; 06-22-2006 at 10:21 AM.. |
damn, i bet that fools a few cali smog inspectors.
poof! gone Last edited by vash; 06-22-2006 at 10:22 AM.. |
I'm next. I just spent another couple hundred on my CIS system with another new P-car wrench and it's still not doing well. Europa your install looks GREAT! I was hesitant to chop up my engine compartment but yours looks like the EFI was there all along.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
![]() ![]() I'm next. I just spent another couple hundred on my CIS system with another new P-car wrench and it's still not doing well. Europa your install looks GREAT! I was hesitant to chop up my engine compartment but yours looks like the EFI was there all along. Thanks Scott! I tried to keep it stock looking as much as possible, but the new airbox cover deffinetely blew my cover! So to speak... I'm trying to squeeze all the HP out of my 3.0. My latest is to convert to an Porsche OEM short shifter, I hear it makes such a big difference in shifting. I'll post pics when I get to it. Scott don't hesitate buy the CIS to EFI kit you will LOVE IT!!! Tony is alot of help and a wealth of information, he really knows his product! Thanks, Mike
Mike 2002 996 911 Carrera Cab 1998 Boxster S 2002 BMW X5 1978 FJ40 Land Cruiser 2005 Jeep Liberty CRD - Diesel www.europautoparts.com Last edited by Europa Auto; 06-22-2006 at 11:04 AM.. |
Now in 993 land ...
What's the plan at smog time? I am still seeing if people pass w/o issues. You should, unless you have a Porsche expert smog tech.
So far my CIS is doing great. I think if it works, it is a decent system. I agree, that when it's old and needs a lot of help, you probably are better off replacing it with EFI. George |
Hi George,
We do not have smog testing issues here in NC, I believe the cutoff point is 1991 or '92, so an '81 911SC is not an issue. In any case the 3.0 is running great, thanks to Bitz Racing for the EFI conversion.
Mike 2002 996 911 Carrera Cab 1998 Boxster S 2002 BMW X5 1978 FJ40 Land Cruiser 2005 Jeep Liberty CRD - Diesel www.europautoparts.com |
Now in 993 land ...
Thanks Mike. For some reason, I thought you are in CA, and didn't check your location.
George |
No problem George.
I know the smog issue is real tough in CA, I don't know how you'all manage out there. Fortunately NC is OK. Not too long ago I purchased a 1978 Land Cruiser that was CA smogged that had all kinds of exhaust reactors, etc. what a mess! But then again clean air is very important.
Here is tony's kit on a 2.7L turbo on my 76'. the car just screams now. No smog check's in Ohio, and as you can see it doesn't look at all like CIS. I am considering selling it this winter and doing the same to a 3.2 or 3.6 on the car.
Oscar Akron, Ohio ![]() |
And picture of car
Hey Oscar,
Your SC looks great and fast! Nice work! How much are you plannig on selling it for?
Mike,
The car is actually a 76' with a 2.7L turbocharged motor. I would probably sell the car for 15k as it is. I don't know what I could get out of just the motor. I just rebuilt the whole motor,turbo,EFI, MSD about 500 miles ago. I am going to put it on a dyno next week to see what it will do. Oscar |
Oscar, not to get off topic here but I would be very interested in knowing more about your turbo setup, i.e., is it a BAE or custom setup.
You can email me if you prefer at mvanwyk at sbcglobal dot net. Thanks!
Michael Sans Porsche...for now 2009 Mazdaspeed 3 Grand Touring daily driver / DS autocross toy 2010 Subaru Forester X Limited - wife's daily driver |
Oscar,
I look forward to your dyno results, please post them if you don't mind.
Did you do it?Osc
Oscar, did you rebuilod the engine yourself?
77 911, 3.0L |
It started out as a BAE set up, but I had to change it when I went to the BB headers,(shortenned). I did the rebuild myself, but had the heads done locally and the case was sent to Tenessee for timecerts and line bore...
I think Tony's kit is super! Here's a link to my finished project:
Tbitz EFI Installed and Car Runs Great!
Dave Taylor 1974 911 Coupe 2.7 Guards Red/Black Trim, Tbitz EFI, MSD 1974 Super Beetle Sun Bug 1959 356A (sold) 1954 Hudson Hornet Project For Sale 18 Years In Storage 1974 911 My Car in the Pelican Gallery |
