need help w/driver's side door
This is a pic of my driver's side door.
I noticed when I open it, it swings all the way to 90 degrees with no friction or stop points. I went to investigate and came across this. Anyone have any guesses as to what's going on here? Would like to get everyone's input as to what happened, and how to fix this correctly.
1987 Porsche 911 Carrera Coupe |
Looks like you need a door stop and door stop repair kit. It basically puts a plate inside of door to receive new door stop. Yours looks pretty torn up, and previously repaired with washers, etc. Parts are available from host. You will need to pull the door card to get at the inside repair. While in there lube and tighten other things you see.
Good luck.Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Lots of thread's on this topic - do just do a search:
Door stay repair without gut opening and welding Door stop replacement. Door Stay Reinforcement Help
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Member 911 Anonymous
+1 check inside, most likely the rubber stop inside is a goner too.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
![]() Thanks for your links!!
