Loud Whine...
Hello all,
I am getting a high-pitched whine coming from the driver's side of the engine compartment when I engage the heater. I can actually hear it from inside the car and it's quite obvious when I step outside. The noise does not seem to be affecting the performace of the heater itself, however I seem to be getting a slight burning smell inside the cabin, although I can't be sure I'm not imagining it . When I turn off the heat, the sound immediately disappears. Does anyone have any idea what may be causing this noise, and do I risk causing further damage if I continue running the heat. Thanks! |
Not sure what your car is, so that may affect the answers.
The heater blower is located on the driver's side inside the engine compartment. It pushes additional air through the system. It's an electrical unit which does wear out after a while. If you can locate it (it's kind of hard to miss); the big electric blower looking thing on the top left of the engine, you'll find a plug at the electrical connection. Unplug and see if your whine goes away. Make sure your wife is not in the engine compartment. That could be another potential source of your problem. chris
'76 911 Carrera 3.0 |
Your heater blower motor is shot. Very common problem. Once you get it out you'll probably find the bearings are shot and the housing is wallowed out. You'd probably be better off disconnecting it until you can replace it. OEM replacements are in the $250 range, or you can try:
Carrera replacement heater blower (long)
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Rennch on YouTube
Maybe someone snuck in overnight and installed a supercharger?
Does the car feel faster? Sorry...
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
yep...my blower just blew one day...smoke coming out of the vents...and the smell...yuk. Pulled out the fire extingusher just incase. Used the same thread to fix mine.
Check Pelican first but I have another source should you need it. Jason 88 911 Cab (with new blower motor) Last edited by cicsprog; 01-22-2004 at 01:56 PM.. |
Jason, watch out for that grenade headed your way. You just might avoid it if you post a corrected link to the pelicanparts listing.
Neil '73 911S targa |
Go Speedracer, go!
I got my car with a non-working blower motor and did the Grainger motor fix. It cost me less than $30 for all the parts and only took about two hours. It was well worth the time and money, and $250 is way too much to buy a new one.
1981 SC ROW Coupe |
Totally agree about Pelican...support this site first....I don't think Pelican had one when I went looking. I will edit the post and PM me for another OEM vendor for the part if Wayne does not have one.
Jason Last edited by cicsprog; 01-22-2004 at 01:57 PM.. |
Thanks for all the replies. You guys are great. And, yes, come to think of it the car does feel a little faster.
Re: Loud Whine...
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
