thanks blokes. by the way, just bought some dodgy looking mag called excellence or excellent or excitement or something that had a tatty old black 911 in it..................................not bad jack!
Thanks.
http://bender.annenberg.edu/pelican/JackOlsen/Rear.jpg Now try to imagine adding a full inch and a quarter, or five centimeters, to each of those rear tires. You're talking wide. :cool: |
are them lights an RSR spec light jack or your own breed?
The lights are 911R style. Not correct for a 911 RSR.
I think the camber is about 3 degrees, maybe less. I'll have to look it up. The big wheels and the shape of the flares make it look more exaggerated, I think. |
going back to the big tyre issue, the inner offset on my banded 11x15 fuch's is 121mm. does this mean that i should be able to use 345/35/15's?
With only 4 and 3/4 inches of backspacing you need to measure from the mounting surface on the hub to the suspension arm bolts and see how much room you have.
Yokohama 345s are 3/4 inch wider than Pirelli 345s. Makes a big difference in this tight fitment. |
| All times are GMT -8. The time now is 01:01 PM. |
