Fuel Distributor bypass valve stock open.
My 78sc has low fuel pressure. Everything but the bypass valve in fuel distributor has been eliminated as a problem. In the bentley manual it dosn't say what to do for a stuck valve. What should I do? Un screw it and flush it out. See if it works when I reinstall it? Get a new one. Is this something I can do with the fuel distributor in the car? Has any one run in to this?
Old 12-20-2003, 06:29 PM
how low? which pressure? control, or system? FD check valves can stick closed and skyrocket the fuel pressure, but rarely stick open. it's got a stiff spring and shims behind it that control the pressure.
206 637 4071
Old 12-20-2003, 07:01 PM
