Steering Wheel Removal
Simple task, remove the steering wheel. Not so simple, the 27 mm in torqued to 500 ft-lbs or more who knows, it is really tight. So the big question, when I crank on it with the cheater bar do I have the steering lock (ingition) disengaged? I'm assuming the answer is yes and should have the wheels turned all the way to the left to they hits the stops. Is the nut left or right thread?
Bill
1987 911 Coupe
Old 12-17-2003, 01:39 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Regular right hand thread, nothing special, just going to have to give it elbow grease.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 12-17-2003, 01:44 PM
Bill, righty tighty, lefty loosey. If you can use an air wrench, while holding on to the wheel, the nut will brake loose with out any problem. Craig
80SC
Old 12-17-2003, 01:45 PM
Thanks, I was unsure if the thread was left hand
1 fastredsc, I'll wave to you as I'm passing on my way to El Paso.
Thanks Again!
Bill
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 12-17-2003, 01:49 PM
scottb's Avatar
Don't use the steering lock to secure the wheel while you're trying to crack the nut loose...you'll bust it!
1984 Targa
Old 12-17-2003, 01:51 PM
RETIRED
Joe Bob's Avatar
Long breaker bar, have a friend hold the wheel. If still too tight a air tool should do it......
HEY... my 5,0000th post.....
2012 ML350 3.0 Turbo Diesel
Old 12-17-2003, 01:56 PM
be careful that when the nut lets loose you don't put your hand and the breaker bar through the windshield.
Old 12-17-2003, 02:14 PM
Detached Member
Hugh R's Avatar
One trick in 101 projects is to use one of those stupid steering wheel anti-theft locks "The Club" to hold the wheel
Hugh
Old 12-17-2003, 02:48 PM
vash's Avatar
just did it last night. i actually sat in the seat and braced the steering wheel with my knees. one crank on the cheater bar loosened it! i guess all the leg squats did the trick. bcorp, you are going to EP? say hi, that is my hometown.
cliff
poof! gone
Old 12-17-2003, 02:52 PM
goat's Avatar
So are you putting on a new style of wheel?
Or is this maintance.
Tim.
1988 911 Carrera. Silver.
1973 914 Metalic Blue.
2012 Cayenne S
Old 12-17-2003, 02:59 PM
vash's Avatar
hey goat, do you do any hunting with that dog of your's? that is a nice dog. any quail hunting up there?
poof! gone
Old 12-17-2003, 03:08 PM
goat's Avatar
Yep. got two of them, we quail and Pheasant hunt. But mostly hunt in the Sacramento delta region.
Tim.
2012 Cayenne S
Old 12-17-2003, 03:38 PM
vash's Avatar
i love watching dogs work.
poof! gone
Old 12-17-2003, 05:42 PM
Adman's Avatar
Send a message via AIM to Adman
Taken out of context of course!
Matthew D.
'87 Carrera Coupe
Guards Red/Cold A/C
PCA Member
Old 12-17-2003, 06:20 PM
As a follow on to this thread...is there something special about removing the horn pad? I have pulled on it pretty hard but it does not want to budge. Do I just yank harder? This is on an 88 coupe.
TIA
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 12-17-2003, 07:53 PM
Binge User
Schrup's Avatar
I used two hands & pulled hard straight off. There is a wire connected to it you'll need to unplug after you get it off.
Paul
Old 12-17-2003, 07:57 PM
vash's Avatar
i am with schrup. this is the most uncomfy thing i did. felt like i was going to break the thing. but the two hand approach is KING! just put two hand on one of the three pads at a time.
cliff
poof! gone
Old 12-18-2003, 10:20 AM
Remove the horn fuse first ( ! )....
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 12-18-2003, 02:07 PM
Unregistered
sammyg2's Avatar
LOL my neighbors know it every time I mess with my steering wheel.
Old 12-18-2003, 02:53 PM
